[AG-TECH] Recording Access Grid Sessions
Natalia Costas Lago
natalia at cesga.es
Sat Jun 11 05:12:45 CDT 2005
we use the control computer as a record machine, the windows media encoder
captures the screen and audio coming from the XAP (both local and remote),
this way we capture the PPT + audio, if VIC is running u can even select the
videostream with the lecturer and overlap it over the PPT. This way we have
a wmv of our seminars, etc.
What i was trying to do now is to record the actual AG session using
RTPdump, with this program i can record video+audio+PPT (as screenstreamer
uses RTP), i still have two problems:
1.- The size of files as all the videostreams are recorded: I'm trying to
solve it using RCBridge
2.- The filesize limit of the files generated by RTPdump (2GB): I've found
some fixes done to RTPdump.c to eliminate that software limit (havent tested
it yet).
Using this second method I can later use windows media encoder to obtain the
wmv record of the session.
Lately i've found a program called MboneVCR, though I havent tested it yet.
Regards.
----- Original Message -----
To: "ag-tech" <ag-tech at mcs.anl.gov>
Sent: Saturday, June 11, 2005 12:20 AM
Subject: Re: [AG-TECH] Recording Access Grid Sessions
> Natalia Costas Lago wrote:
>> I found this post to the mailing list. I was wondering if u devised any
>> way or idea to do that. So far the only way we found to do that was doing
>> a screen capture with windows media encoder on a PC running the VIC and
>> RAT (so u can capture a PPT with several small VIC video windows over
>> it).
> When working on the Descent to the Underworld project, we made screen
> captures of sessions using Camtasia Studio, a relatively inexpensive and
> fairly powerful tool; it is often used for capturing screens for online
> tutorials.
> However, for this to work properly, I believe you need a machine dedicated
> to session recording, so that all sound is coming thru RAT. I was able to
> record visuals only, since I was using one machine for AG and Camtasia.
> Any attempt to also record sound from both teams (mike and speakers)
> generated a massive echo. :-/
> I believe Druid eventually used a digital camcorder to capture the screen
> and sound.
> Kathy
> Kathy E. Gill
> Department of Communication
> Digital Media Master's Degree Program
> University of Washington
> Box 353740 Seattle WA 98195 USA
> http://faculty.washington.edu/kegill/
