[AG-TECH] Venue and Bridge Server specs
Natalia Costas Lago
natalia at cesga.es
Fri Jun 10 02:14:46 CDT 2005
Is it dual or single processor?
----- Original Message -----
To: "Andrew Rowley" <Andrew.Rowley at manchester.ac.uk>
Cc: "'ag-tech'" <ag-tech at mcs.anl.gov>
Sent: Thursday, June 09, 2005 6:38 PM
Subject: Re: [AG-TECH] Venue and Bridge Server specs
> Agreed on the crashing. Our venueserver hasn't had any problems and it
> runs 24/7. It usually only needs to be restarted about once ever month or
> so...
> Concerning configuration and setup, our main venueserver runs on the same
> machine as one of our bridges, while a second machine serves mostly as a
> second bridge (geographically separated) but can serve as a backup
> venueserver in times of crisis.
> One machine is a P3 1Ghz, the other a P4 2.8Ghz, both with 2 GB of mem.
> Neither has had an issue with performance and we host some fairly large
> meetings occassionally...
> Todd
> Collaboration & Visualization Technician
> WestGrid - www.westgrid.ca
> IRMACS - www.irmacs.com
> Ph. 604.268.6979
> Todd Zimmerman - toddz at sfu.ca
> Derek Piper wrote:
>> Your VenueServer crashes a lot? hmm. I actually run ours on the same
>> machine that does our Audio and Video for the node we have here. This was
>> simple because when I was installing it last year, it was deemed that
>> that was 'the AccessGrid Linux machine'. Whether that's smart or not, I
>> don't know, but I've found it to be very stable. It's a single P4/3Ghz
>> with 1GB RAM. The machine was recently reformatted and reinstalled (now
>> Debian Sarge instead of RedHat 9) because of a failing harddrive (Dell
>> and their Maxtors ... sheesh). The VenueServer had to be restarted
>> occaisionally, but I'm thinking it was a few months between intervals. We
>> have a bridge server on a different machine (another 3Ghz P4 that does
>> web stuff), since because of the audio and video VICs on the AV machine,
>> they cannot occupy the same machine.
>> Derek
>> Andrew Rowley wrote:
>>> Relating to this, I also wondered if people generally run their bridge
>>> server and venue server on the same of separate machines?
>>> We currently run ours on the same machine (a P4 1.7Ghz with 512MB RAM).
>>> The
>>> venueserver crashes fairly often, and I sometimes find that restarting
>>> the
>>> bridge server helps, so I assume the bridge server sometimes puts a lot
>>> of
>>> load on the server.
>>> Andrew :)
>>> Access Grid Support Centre,
>>> RSS Group,
>>> Manchester Computing,
>>> Kilburn Building,
>>> University of Manchester,
>>> Oxford Road,
>>> Manchester,
>>> M13 9PL,
>>> UK
>>> Tel: +44(0)161-275 0685
>>> Email: Andrew.Rowley at manchester.ac.uk
>>> ________________________________________
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>> Behalf
>>> Of Natalia Costas Lago
>>> Sent: 09 June 2005 08:39
>>> To: ag-tech
>>> Subject: [AG-TECH] Venue and Bridge Server specs
>>> Dear all,
>>> Seeking for some information related to the hardware I need for our own
>>> venue/bridge server I found two threads with no answer to this question.
>>> It seems to me that the venue server doesnt need heavy resources, but
>>> I'm
>>> not so sure about the bridge server.
>>> I would really appreciate the sites that hold/organise very big
>>> meetings (as
>>> Argonne with SCGlobal for instance), and have much experience in these
>>> matters, give us some guidelines about the specs recommended (or the
>>> place/website where I could gather some information). Kind regards,
>>> Natalia.
>>> Natalia Costas Lago
>>> email: natalia at cesga.es
>>> Centro de Supercomputacion de Galicia (CESGA)
>>> Avenida de Vigo, s/n Campus Sur 15706 Santiago de Compostela - SPAIN
>>> Tel: +34 981 56 98 10 Fax: +34 981 59 46 16
>>> http://www.cesga.es/
