[AG-TECH] Can not enter venue with Thinkpad T43
Anne Gorczyca
amg at haystack.mit.edu
Thu Jun 9 10:11:49 CDT 2005
Hi everyone,
I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43 running
XP w/ SP2. We've performed installations on several systems using the
same set of files. However, after obtaining a certificate and trying to
enter a venue, it lmost immediately pops up "Can not connect to venue
located at https://vv2.mcs.anl.gov:9000/Venues/default. Please, try
again."
We've consulted the archives and the buglist and found out that there
have been problems with the Thinkpads, but we've changed all the
environmental variables to point to python23 instead of the python22
that comes preloaded from IBM. I've set GLOBUS_HOSTNAME to localhost
even though I'm just trying to use wired ethernet, not WLAN. I've set
PYTHONCASE to _unset_. What else can I try?
When the client is brought up in debug mode this is what's displayed:
C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCTNL module is
deprecated; please us fcntl
DeprecationWarning>
C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS module is
deprecated; please us termios
DeprecationWarning>
Attached is a portion of the VenueClient log showing one attempt this
morning to connect to a venue.
Thank you for any suggestions!
Anne
Anne M. Gorczyca
M.I.T. Haystack Observatory
Westford, MA 01886
Phone: 781-981-5630
FAX: 781-981-5766
06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO --------- END VenueClient
06/09/05 10:12:43 1040 DataStore datastore.py:1577 DEBUG Quitting thread 0
06/09/05 10:12:43 3412 DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG Worker 0 exiting
06/09/05 10:12:43 3416 DataStore datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
06/09/05 10:12:43 1040 NodeService agnodeservice.py:113 INFO NodeService.Stop
06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:85 INFO Remove services
06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379 INFO AGServiceManager.RemoveServices
06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:87 INFO Stop network interface
06/09/05 10:12:43 3436 Hosting server.py:65 ERROR Exception in SOAP server main loop
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
06/09/05 10:12:43 1040 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
self._server.server_close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
06/09/05 10:13:23 3008 Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock: Connection to sntp server at ntp-1.accessgrid.org failed
File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line 176, in __CheckForInvalidClock
serverTime = GetSNTPTime(timeserver, timeout)
File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py", line 43, in GetSNTPTime
client.sendto( data, (server, 123 ))
gaierror: (7, 'getaddrinfo failed')
06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=localhost as set in the environment
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:257 DEBUG Opened repository C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\certRepo
06/09/05 10:13:23 3008 Toolkit toolkit.py:395 DEBUG Got repo.
06/09/05 10:13:23 3008 Toolkit toolkit.py:397 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
06/09/05 10:13:23 3008 Toolkit toolkit.py:410 DEBUG Init'ing globus.
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:734 DEBUG Configuring standard environment
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:802 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:873 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:892 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:895 DEBUG Proxy C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05 16:10:02
06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG Done with globus.
06/09/05 10:13:23 3008 VenueClient venueclient.py:284 DEBUG __StartWebService: venueclient: https://localhost:11000/VenueClient
06/09/05 10:13:23 3008 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\local_services
06/09/05 10:13:23 3008 ServiceManager agservicemanager.py:414 INFO __DiscoverResources
06/09/05 10:13:23 3008 Toolkit config.py:997 INFO Using vfwscan to get devices
06/09/05 10:13:23 3008 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe
06/09/05 10:13:23 3008 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
06/09/05 10:13:23 3008 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
06/09/05 10:13:23 3008 VenueClient venueclient.py:293 DEBUG __StartWebService: service manager: https://localhost:11000/ServiceManager
06/09/05 10:13:23 3008 NodeService agnodeservice.py:733 INFO NodeService.__ReadConfigFile
06/09/05 10:13:23 3008 Toolkit toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
06/09/05 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 10:13:23 3008 NodeService agnodeservice.py:745 INFO Reading node service config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG __StartWebService: node service: https://localhost:11000/NodeService
06/09/05 10:13:23 3008 VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node service url: https://localhost:11000/NodeService
06/09/05 10:13:23 3008 NodeService agnodeservice.py:675 INFO NodeService.GetDefaultConfiguration
06/09/05 10:13:23 3008 NodeService agnodeservice.py:558 INFO Migration unnecessary
06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO NodeService.LoadDefaultConfig
06/09/05 10:13:23 3008 NodeService agnodeservice.py:355 INFO Loading default node configuration: defaultWindows
06/09/05 10:13:23 3008 NodeService agnodeservice.py:369 INFO NodeService.LoadConfiguration
06/09/05 10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to load node configuration from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
06/09/05 10:13:23 3008 NodeService agnodeservice.py:358 ERROR Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 356, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 500, in LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: localhost:11000
06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR Error loading default configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 308, in __StartWebService
self.ns.LoadDefaultConfig()
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
06/09/05 10:13:23 3008 VenueClient venueclient.py:182 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
06/09/05 10:13:23 3008 DataStore datastore.py:1500 DEBUG Creating thread 0
06/09/05 10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting thread 0
06/09/05 10:13:23 3088 DataStore datastore.py:1513 DEBUG Worker 0 starting
06/09/05 10:13:23 3008 DataStore datastore.py:1507 DEBUG Waiting thread 0
06/09/05 10:13:23 3008 DataStore datastore.py:1510 DEBUG Done creating workers
06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG Reading persisted data from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
06/09/05 10:13:23 3008 VenueClient venueclient.py:207 DEBUG __createPersonalDataStore: Load personal data from file
06/09/05 10:13:23 3008 VenueClientController venueclientcontroller.py:1277 DEBUG There is no personal venues file to load.
06/09/05 10:13:27 3008 VenueClient venueclient.py:803 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 10:13:27 3008 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 10:13:27 3008 CertificateManager certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca/CN=proxy
06/09/05 10:13:27 3008 VenueClient venueclient.py:830 INFO EnterVenue: Error getting node capabilities
06/09/05 10:13:27 3008 VenueClient venueclient.py:702 DEBUG EnterVenue: Invoke venue enter
06/09/05 10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue: failed
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 834, in EnterVenue
self.__EnterVenue(URL)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 703, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331, in Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
config = self.config, noroot = self.noroot)
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in buildSOAP
return t.build()
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in build
body_ns = self.genns(ns_map, NS.ENV)[0]
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in genns
if type(nsURI) == TupleType: # already a tuple
NameError: global name 'TupleType' is not defined
06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 10:13:27 3008 VenueClient venueclientui.py:1972 DEBUG warningString:
