[AG-TECH] RAT development on windows
    Rajvikram Singh
    rsingh at evl.uic.edu
    Tue Jul 19 17:15:46 CDT 2005
Hi Derek
	Thanks for the input. I was just able to get the RAT 4.2.23
distro to build under VC++ after a fair of code tweaks ... there
were some function overloading of win32 functions that the compiler did
not like.
	The ratui.exe did not build in te debug mode but seemed to
compile fine in the Release mode ... It kept complaining about how it
could not link with the ws2_32.lib library because it might have been
built with a later version of the compiler/linker ... whatever.
Anyways the executables seem to be partly functional so my problem has not
gone away completely.
Raj
Rajvikram Singh,		   |		Ph no :	312-996 3002 (EVL)
Research Assistant,		   |			312-421 7266 (Res)
Electronic Visualization Lab.	   |		Fax no:	312-413 7585 (EVL)
Univ. of Illinois at Chicago.	   |		Url:www.evl.uic.edu/rsingh
On Tue, 19 Jul 2005, Derek Piper wrote:
> 	It may be possible to build RAT on Windows under an MinGW / MSys setup.
> I've not built RAT in that way, just done that builds of other unix
> programs on a Windows environment to get GCC to spit out Windows
> executables. It might be a way forward for you?
> 	Derek
> Rajvikram Singh wrote:
> > Hi
> > 	I'm trying to modify the RAT code, in order to integrate it with a
> > video streaming system called TeraVision. TeraVision supports HDTV quality
> > streaming and has a foot in the door in the AG-framework as a service.
> > 	I was successful in tmodifying the RAT code on Linux but under
> > windows, I'm running into basic compiler/linker errors with incompatible
> > .h or libs. My question is very basic ... has anyone tried compiling the
> > RAT distro under windows ? If yes, what was the development setup, I'm
> > using
> > [1] Visual Studio 6.0
> > [2] Have tred both intel and MS compilers
> > [3] Latest platform SDK
> > [4] Machine is updated with all patches/service packs
> > Any help would be greatly appreciated ...
> > Raj
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
