[AG-TECH] Gentner AP400
John I Quebedeaux Jr
johnq at lsu.edu
Tue Jul 19 09:29:33 CDT 2005
Impedance an issue? Need something like the MM100? (MatchMaker). I
know that was part of some of the older setups. If you need one... i
have a couple I don't use anymore...
-JQ
John I. Quebedeaux, Jr.
Louisiana State University
Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339
Johnston Hall
e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu
& http://cct.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On Jul 18, 2005, at 9:57 AM, Jeremy Mann wrote:
> I'm so close to getting this thing to work. I finally got the serial
> working and setup the machine exactly like the document shows.
> However,
> echo cancelling was still not working, so I built a custom Preset 1
> that
> worked.
> Several problems occured however, the audio out was extremely low.
> I had
> the gain for Output D cranked all the way up and we could barely
> hear the
> talking. Second, the mic inputs were somehow overloaded and would
> constantly clip. Adjusting the levels didn't work, it was either
> overloaded or too soft to pick up anything.
> Natalia Costas Lago said:
>> There's a pinout scheme for the XAP400 serial cable, probably
>> there's one
>> for the AP400. Make a cable with the exact pinout, just to be sure
>> u r
>> using
>> the right one.
>> ----- Original Message -----
>> From: "Jeremy Mann" <jeremy at biochem.uthscsa.edu>
>> To: "John Hodrien" <johnh at comp.leeds.ac.uk>
>> Cc: <ag-tech at mcs.anl.gov>
>> Sent: Wednesday, July 06, 2005 3:36 PM
>> Subject: Re: [AG-TECH] Gentner AP400
>>> John Hodrien said:
>>>> On Tue, 5 Jul 2005, Darin Oman wrote:
>>>>> Hi Jeremy,
>>>>> Are you sure the serial port on the computer is enabled/working?
>>>> ClearOne recommended disabling the hardware flow control when we
>>>> had
>>>> problems
>>>> with connecting to the device.
>>> Thanks John, but I tried all the settings in the RS232 menu and
>>> it still
>>> didn't work. I'm going to try some cables. I know the cable from our
>>> managed switch works so I'm going to try that cable next.
>>> Jeremy Mann
>>> University of Texas Health Science Center
>>> Bioinformatics Core Facility
>>> http://www.bioinformatics.uthscsa.edu
>>> Phone: (210) 567-2672
> Jeremy Mann
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050719/a1e8450a/attachment.htm>
