[AG-TECH] Multi Display Cards Recommendation
    Natalia Costas Lago
    natalia at cesga.es
    Tue Jul 12 01:15:50 CDT 2005
We bought a Matrox QID PCIe Low Profile and got the same problem. It seems
we found a workaround that was to replace VIC 1.1.3 by VIC 1.1.6 (i got this
version from UCL mbone tools that is more or less the same but a few
changes).
----- Original Message -----
From: "Peter DeSantis" <peter at jumbovision.com.au>
To: "John I Quebedeaux Jr" <johnq at lsu.edu>
Cc: "Derek Piper" <dcpiper at indiana.edu>; "Todd Zimmerman" <toddz at sfu.ca>;
"'ag-tech'" <ag-tech at mcs.anl.gov>; "Westgrid-AGTECH"
<westgrid-agtech-l at majordomo.netera.ca>
Sent: Tuesday, July 12, 2005 3:41 AM
Subject: re[4]: [AG-TECH] Multi Display Cards Recommendation
> We used XP sp2, Asus mainboards, 3.0ghz intel cpu etc etc.
> Im sure i sure 1 or 2 posts from someone else about this issue and that
> there possibly was a fix, but we never tested it out.
> I think the post stated links to 2 upgraded versions of vic that they
> stated fixed the problem, but it wasnt clear that they were in fact
> running in independentat screen mode to see the problem.
> As for the resolution matrox claim there is a tool on thier wesbite that
> allows you to add this custom resoltuion, but i aint testededd it.
> For what it is worth my opinion is that if you aint gonna use one of the
> vic variations that allow greater than 388x252 pixel capture you should
> not look to use anyhting higher than 1280x1024.
> Peter
> >>  Hi Peter, I realize this is a month later... but going  back through
> >>  messages I found yours.
> >>  Well, I can confirm this behavior as well with the product now having
> >> just
> >>  gotten the card in one of our nodes to try. I haven't tried that
> >>  resolution though, but have the screen corruption you talked about.
> >> Did
> >>  it happen with any other application besides Vic?Any fix to this
> >> problem?
> >>  Seemed to duplicate from screens 1 to 2 and 3 to 4. So we had to
> >> resort
> >>  to the stretch  mode and since our setup was just 2 projectors and 2
> >>  monitors we went with 2x2 such that the windows taskbar stayed on the
> >>  operator monitors and had to drag stuff "up" to the projectors.
> >> Annoying
> >>  for me, but worked.
> >>  Which OS were you doing this on?
> >>  Thanks, John Q.
> >>  John I. Quebedeaux, Jr.
> >>  Louisiana State University
> >>  Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339 Johnston
> >>  Hall
> >>  e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu
> >>  http://cct.lsu.edu
> >>  phone: 225-578-0062 / fax: 225-578-2597
> >>  On Jun 9, 2005, at 8:49 PM, Peter DeSantis wrote:
