[AG-TECH] Node configs - Laptop on different networks
    Michael Miller
    myk at ncsa.uiuc.edu
    Wed Jan 12 13:21:03 CST 2005
Probably should mention the node config files are stored in:
C:\Documents and Settings\<user>\Application Data\AccessGrid\Config\nodeConfig
or
/home/<user>/.AccessGrid/Config/nodeConfig
MYK
At 01:13 PM 1/12/2005, Michael Miller wrote:
>I use my laptop on several different networks here at NCSA.  I get a
>different IP address.  this causes problems with configurations in that
>the IP number is stored in the config.  So I simply went and edited the
>file and put 'localhost' in place of the IP number:
># AGTk 2.3 node configuration
>[node]
>servicemanagers = servicemanager0
>[serviceconfig0]
>outputgain = 50
>inputgain = 50
>talk = Off
>[service0]
>packagename = AudioService.zip
>resource = resource0
>serviceconfig = serviceconfig0
>[servicemanager0]
>url = https://localhost:11000/ServiceManager
>services = service0
>name = vivace:11000
>[resource0]
>resource =
>type = None
>Now I can roam the various networks without messing with my configuration
>each time.  Is there a way to do this in the GUI?  If not, I'll add it as
>a feature request.
>Thanx,
>Michael Miller
>System Engineer
>Visualization Technology Support
>Computing and Data Management
>National Center for Supercomputing Applications
>University of Illinois - UC
>217-649-0747
>"If you're clear in your vision and trust the people in your team with
>clear objectives, they will invariably do their best to achieve everything
>desired, and usually deliver everything you could have hoped for and even
>more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
