[AG-TECH] Text in VIC window title bar
    Michael Miller
    myk at ncsa.uiuc.edu
    Wed Jan 12 11:05:49 CST 2005
The problem I see is that when vic goes to grab the video devices, they get
grabbed in a different order. for example if I get this the first time around:
vic1 - cam1
vic2 - cam2
vic3 - cam3
vic4 - cam4
the next time around cam4 is the default so it gets grabbed first:
vic1 - cam4
vic2 - cam1
vic3 - cam2
vic4 - cam3
so now the names I've designated in the Node config are different from the
other control software I use for the cameras.
The next time around cam3 is the default so I get
vic1 - cam3
vic2 - cam1
vic3 - cam2
vic4 - cam4
so you can see how confusing it gets.  This is the same problem when using
two Logitech Quickcams on a windows machine.  It occurs each time you enter
a venue and vic is restarted.
Is there some way to assure that the same vic->video0->cam1 combination
comes up each time you move to a new venue?  It's more of a vic problem
than an AG problem Iguess so should I file a bug on this?
MYK
At 10:47 AM 1/12/2005, Monika Rabarison wrote:
>hmm. No problem for me to rename and save the stream name on both single
>machine node running XP and room node with video capture on FC2.
>On Wed, 12 Jan 2005, Joe Reitzer wrote:
> > Hi,
> > I have had the same problems - drives me crazy.
> > Do you have a one machine node or multiple.  Not so bad on a single
> machine
> > on Win XP.
> > You have to hit return in the vic window immediately - if your mouse moves
> > off of the line you are typing it is too late for it to be saved.  On the
> > multiple machine node with the video capture OS being FC2, I can even
> add a
> > second line to get rid of the email address which I would love to do.  I
> > set this in each of the vic capture windows - the return rule applies
> there
> > too.  As soon as I leave the venue that I set it in - I lose the
> > information.  How I long for a video.cfg file.
> > At 09:52 AM 1/12/2005 -0600, Monika Rabarison wrote:
> > >Andy,
> > >I just tested the steps that Tom indicated for renaming the video stream
> > >and I got the stream name changed and saved. I have JSU SciVis PIG
> > >currently in the ANL Venue Server Lobby at
> > >https://vv2.mcs.anl.gov:9000/venues/default
> > >I changed the stream name to Camera.
> > >Monika
> > >On Tue, 11 Jan 2005, A Quay wrote:
> > > > Hi Tom,
> > > > Correct - I understand the process of naming my video streams. But when
> > > > I view my node's video thumbnails in VIC, they all have a stream
> name of
> > > > "Video" instead of "Camera 1", "Camera 2", etc. And other nodes see my
> > > > stream names as "MYNODENAME (Video)".
> > > > I've saved the node config as the default and even rebooted.
> > > > Just for curiosity, I checked out
> > > > https://venues.ncsa.uiuc.edu:9000/Venues/default and noticed that
> > > > everyone's streams have VIDEO in their stream name.
> > > > Any thoughts?
> > > > -andy
> > > > -----Original Message-----
> > > > From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> > > > Sent: Tuesday, January 11, 2005 2:14 PM
> > > > To: A Quay
> > > > Cc: ag-tech
> > > > Subject: Re: [AG-TECH] Text in VIC window title bar
> > > > Andy:
> > > > You can set the stream name as you like, by configuring the video
> > > > producer service (or
> > > > video service).  In the VenueClient, select Preferences->ManageMyNode,
> > > > double-click the
> > > > VideoProducerService, and change the stream name.  If you want the name
> > > > to persist, store
> > > > the node configuration.
> > > > Tom
> > > > A Quay wrote:
> > > > > At one time, when clicking on a video thumbnail in VIC, the title bar
> > > > of
> > > > > the opened video window was titled the name of the remote site
> > > > appended
> > > > > with the video stream name (camera name). I've noticed that
> everyone's
> > > > > window now has "Their name (Video)" for all of their camera feeds.
> > > > > Is there any way to change this back to the way it was? Having the
> > > > > camera name in the window title bar makes it much easier to arrange
> > > > the
> > > > > video windows on the desktop.
> > > > > i.e.  University of Florida (audience), University of Florida
> > > > > (presenter), University of Florida (VCR)
> > > > > Andy Quay
> > > > > Digital Worlds Institute, University of Florida
> > Joe Reitzer - Coordinator of Technological Services
> > Technology Research Education Commercialization Center
> > National Center for Supercomputing Applications
> > University of Illinois at Champaign-Urbana
> > TRECC
> > 2700 International Drive
> > Suite 305
> > West Chicago, IL 60185
> > www.trecc.org
> > 630-578-4223
> > 630-578-4210 - fax
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
