[AG-TECH] Fedora Core 3 and rat
Douglas Kosovic
douglask at itee.uq.edu.au
Sun Feb 27 19:17:51 CST 2005
Hi Jeremy,
On Fri, 25 Feb 2005, "Eric Olson" wrote:
> If you haven't already, make sure fedora's firewall isn't preventing
> rat from getting multicast.
> I usually clear it with "/sbin/iptables -F" since we have an external
> firewall. You could probably also disable the service "/sbin/service
> iptables off". Make sure to turn it back on or poke the appropriate holes
> in it if you need a firewall.
> Eric
> On Fri, 25 Feb 2005, Jeremy Mann wrote:
>> I just install Core 3 RPMs from
>> http://www.itee.uq.edu.au/~grangenet/ag_fedora
>> and rat doesn't come up. I see that the release 2.3-5 from November had
>> this problem fixed. Did 2.3-6 reintroduce the problem?
The AccessGrid 2.3-5 RPM rat fix was primarily for the Fedora Core 1 RPMs
where the OSS sound driver was used instead of ALSA, and subsequently rat
would fail to appear. The fix just involved recompiling rat with an older
g++, a few weeks later Steve Smith came out with a patch which cleaned up
the rat code and worked with whatever g++ version.
So it's most likely a Firewall related issue like Eric mentioned.
Cheers,
Doug
