[AG-TECH] Vic.exe error
    Nora Barry
    norabarry at druidmedia.com
    Wed Feb 23 06:44:27 CST 2005
Thanks.
I did connect finally with 2 other endpoints in Seattle and Washington by
going unicast, though my video was choppy.  I will switch out the camera and
see if it makes a difference.
However, after about 10 minutes, I received another "vic.exe" error and it
shut down. I re-started and ran for a short period of time, then it froze
and I received a "python.exe" error.
Any thoughts?
Nora
www.druidmedia.com
----- Original Message -----
To: "Thomas D. Uram" <turam at mcs.anl.gov>; "Nora Barry"
<norabarry at druidmedia.com>
Cc: <ag-tech at mcs.anl.gov>
Sent: Wednesday, February 23, 2005 4:20 AM
Subject: Re: [AG-TECH] Vic.exe error
> I had a similar problem with a Logitech webcam on my Windows XP
workstation.
> I couldn't resolve it, as it seemed to be a driver problem. Maybe a driver
> update could have fixed the problem, but I didn't look out for a new
driver
> update, but switched over to another webcam.
> FYI, I think I used a Logitech QuickCam Messenger.
> Michael
> From: "Thomas D. Uram" <turam at mcs.anl.gov>
> To: "Nora Barry" <norabarry at druidmedia.com>
> Sent: Tuesday, February 22, 2005 7:31 PM
> I think you mean that you can receive, but not transmit.
> I've seen this problem when the selected capture source is no longer
> present, which can be
> the case if the camera has been unplugged, or the card has been removed
from
> the machine.
>   In either case, you can't get data through the selected driver.
> Make sure the camera works in other applications, note the driver, and try
> to use the same
> one in vic.  If you have problems here, update/reinstall the camera
driver.
> Do you have multiple options for capture source in the 'configure on
> transmit' window?
> Tom
> Nora Barry wrote:
> > Hi,
> > I have not been able to receive video, tho I can transmit it.  I
followed
> > the tutorial for video troubleshooting. The steps I took were these:
> > à      Encoder
> > à      Options
> > à      Configure on transmit
> > à      Video format
> > à      Camera controls
> > à      Capture source
> > When I hit apply in capture source, I received a “vic.exe” error and it
> > shut down.  This has happened 4 or 5 times.  I de-installed and then
> > re-installed everything...and the same thing happened. Any ideas?
> > Thanks,
> > Nora Barry
> > www.druidmedia.com/index_sub.html
> > <http://www.druidmedia.com/index_sub.html>
