[AG-TECH] audio levels and sound quality
    Michael Miller
    myk at ncsa.uiuc.edu
    Mon Feb  7 11:00:17 CST 2005
RAT has a feature that sends a tone.  Look in Options->Audio->Tone Test
This will send a test tone that you can use to even out the 6 nodes.
My suggestion tho' is to implement a practice of using a laptop or your
control machine to run another instance of RAT that you can listen
to.  this allows you to determine the level of visiting site in relation to
your site and make adjustments on your broadcasting RAT as
appropriate.  You will inevitably find that in some cases, your stock
settings don't work certain situations.
Take a look at my Quality Audio for the AccessGrid doc:
http://www.accessgrid.org/agdp/guide/XAP800/1.04/book1.html
There are several tips there for producing good quality audio.
Please let me know if you have any questions.
Michael Miller
NCSA
At 06:15 AM 2/7/2005, Natalia Costas Lago wrote:
>Hi everybody,
>We are trying to set all the audio levels of our 6 AG nodes in a proper
>way. I am looking for a way to check that all audio levels are the same
>(is there any audio tool available?).
>Any help about this matters would be greatly appreciated. We are having
>lots of problems to get good audio.
>Thanx in advance.
>Kind regards,
>Natalia.
>Natalia Costas Lago
>email: <mailto:natalia at cesga.es>natalia at cesga.es
>Centro de Supercomputacion de Galicia (CESGA)
>Avenida de Vigo, s/n Campus Sur
>15706 Santiago de Compostela - SPAIN
>Tel:   +34  981 56 98 10
>Fax:  +34  981 59 46 16
><http://www.cesga.es/>http://www.cesga.es/
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
