[AG-TECH] more certificate issues
Thomas D. Uram
turam at mcs.anl.gov
Sun Aug 21 20:23:19 CDT 2005
Richard:
Can you describe the problem in detail?
Have you looked at the logfiles as I suggested? If you don't see
anything wrong there, I'd be happy to take a look to help you out.
The cert request is transferred over http. If you're using Windows, and
have multiple protocol-specific proxy servers defined, submission of the
cert request will fail; you can fix this by specifying only an http
proxy (temporarily removing the other proxy server specs).
Tom
Christoph Willing wrote:
> On 22/08/2005, at 9:07 AM, Richard Caladine wrote:
>> Dear All,
>> I am still having problems obtaining a certificate and am starting to
>> think laterally about where the problem may be.
>> Could it be that the proxy server and/or the border firewall at my
>> institution are blocking the communication?
> Yes it could. A quick test of this is to run an ordinary browser and try
> reaching some well known web sites e.g.
> www.uow.edu.au
> www.usyd.edu.au
> www.ap-accessgrid.org
> www.accessgrid.org
> If you're asked for a password to browse beyond uow.edu.au, then it
> looks very much like a proxy issue.
> A second possibility is the MTU. Are you using Linux? If so, then I've
> recently found that changing the MTU from 1500 to 1476 cured a problem
> that looked a bit like a proxy and/or firewall problem. In that case,
> the browser would reach www.usyd.edu.au, but could not reach
> www.ap-accessgrid.org (which is "nearby").
>> What protocol does the certificate wizard use to communicate the
>> request to the AG developers?
> I believe its https (hence simple browser tests, as above, can give some
> help in this case).
> chris
> Christoph Willing Ph: +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
