[AG-TECH] Re: your mail
Locatis, Craig (NIH/NLM/LHC)
locatis at nlm.nih.gov
Mon Aug 8 10:05:15 CDT 2005
This problem appears new to us also......
-----Original Message-----
From: Gavin W. Burris aka 86 [mailto:ga5in at psu.edu]
Sent: Monday, August 08, 2005 7:04 AM
To: Locatis, Craig (NIH/NLM/LHC)
Cc: 'John Hodrien'; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Re: your mail
I just had the same problem here! We tried all the sound, mixer, and
rat options to no end. The funny thing is that this system was fine a
week ago.
I tried blowing away the Access Grid settings under Application Data, no
go. Does anyone know where RAT stores its settings in the registry?
Locatis, Craig (NIH/NLM/LHC) wrote:
> We've experienced the same problem here at NLM on our XP
> machine..............
> From: John Hodrien [mailto:johnh at comp.leeds.ac.uk]
> Sent: Monday, August 08, 2005 7:27 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Re: your mail
> On Mon, 8 Aug 2005, Peter DeSantis wrote:
>>Hi,
>>has anyone come across an issue with the AG 2.3 software where you find
> that
>>you can not receive (hear) audio from any other participants unless your
>>local "talk" option is enabled. Also i would have expected full duplex
>>audio operation to allow one to speak and receive audio simultaneously,
> but
>>it also appears that when you speak locally and start to transmit audio it
>>cuts of the incoming audio. Is this normal ?
> Definitely not normal. Have you got the dodgy software based echo
> cancellation turned on in rat or something?
>>Ive come across this on two XP based machines now. It dont appear to be a
>>networking issue in that once talk is enable others can be heard fine. In
>>both cases the machines had different audio cards, and one is single Pc
> the
>>other a 3 pc system.
> Doesn't happen with any of our 2000 or linux based machines.
> jh
Senior Systems Programmer
Penn State Visualization Group
http://viz.aset.psu.edu/ga5in
