[AG-TECH]Unicast bridge issues.
John Hofmann
hofmannj at cookman.edu
Fri Apr 29 10:29:31 CDT 2005
RAT reports which udp port is in use, so it's easy to create an
exception in the Windows XP firewall.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Jason Soohoo
Sent: Friday, April 29, 2005 10:08 AM
To: Brian Tieman
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH]Unicast bridge issues.
Hi Brian,
I've seen some similar problems before, On a WinXP system, if the XP
firewall is up, I've seen it block the audio services. Or even in
general
if there is a firewall inbetween the the laptop subnet (wireless
router?)
there could be blockage there.
On a MacOSX system, Some reason it doesn't support encrypted Venues. We
have our own Bridgeserver here, The Powerbook couldn't see anyone due to
the Venue had encryption on. Once I dropped encryption, it worked fine.
I hope this will help!
Jason SooHoo
MIT Haystack Observatory
On Tue, 26 Apr 2005, Brian Tieman wrote:
> Hi all!
> I've got a local venue up and running and clients on several different
> subnets. Some of the clients can share AV just fine, but some can
not. In
> particular, I have a wireless laptop that can not get audio or video
from any
> other machine.
> It was suggested that maybe the bridgeserver would help as it was
believed
> wireless tends to block multicast. So, I've no installed and
configured the
> bridgeserver to work.
> This had the result of allowing some of the machines on different
subnets to
> now share video--whereas previously the could not, but the wireless
laptop
> still can not participate (the wireless laptop can share apps, data,
> etc...just not audio or video). Also, only the video seems to work
over
> unicast--the audio does not appear to be shared. That is, RAT does
not list
> any audio sorces except for the local machine.
> Anyone got any ideas of what might be going on? The bridgeserver puts
us in
> a marginally happier place, but I'm still counting on being able to
link in
> the wireless laptop--which I currently can't do. If anyone has an
idea of
> what to look at or where, I would be very greatful!
> Thanks!
> Brian Tieman
> Advanced Photon Source
> Argonne National Laboratory
> !DSPAM:426ea9d8191391100417974!
