[AG-TECH] shared presentation fails to load presentation
Michael Braitmaier
braitmaier at hlrs.de
Fri Apr 29 10:13:45 CDT 2005
Looking at the Logfile, this seems to be a problem with your windows
machine, possible due to win2k.
The following line in the log
File "SharedPresentation.py", line 156, in LoadPresentation
> self.presentation = self.ppt.Presentations.Open(file)
> File
> "C:\Python23\Lib\site-packages\win32com\gen_py\91493440-5A91-11CF-8700-00AA0060263Bx0x2x7.py",
> line 3749, in Open
> ret = self._oleobj_.InvokeTypes(2005, LCID, 1, (13, 0), ((8, 1), (3,
> 49), (3, 49), (3, 49)),FileName, ReadOnly, Untitled, WithWindow)
> com_error: (-2147352567, 'Exception occurred.', (0, None, None, None,
> 0, -2147467259), None)
> 04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1502
> ERROR SharedPresentation.LocalLoadVenue: Can not load presentation
states that an OLE automation error (-2147352567) occured, which is caused
within the OLE component of Powerpoint.
I found a link to a forum discission where a reference is made to different
MDAC versions installed on your machines. Possibly that would be a point to
checkout. If thats the case maybe you should consider upgrading your MDAC
component.
Still there seem to be other possibilities. I add the link to the foruum
discussion for reference and hope it helps.
http://www.mail-archive.com/vbpro_databases@p2p.wrox.com/msg00383.html
Michael
----- Original Message -----
To: <ag-tech at mcs.anl.gov>
Sent: Thursday, April 28, 2005 10:02 PM
Subject: [AG-TECH] shared presentation fails to load presentation
>I have been working around this for awhile, fresh install of win2k, ag2.3.
>I can open a shared presentation, the control window pops up along with
>powerpoint app, it downloads the ppt file but then I get a popup window
>that it couldn't load the presentation. I found a similar report on the
>ag-tech mailing list last November but there were no replies. I included
>the shared presentation log message below. This problem look familar to
>anyone?
> Mike Blodgett
> UW-Madison,CS
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:90 DEBUG Initializing AG
> Toolkit version 2.3
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:132 INFO Logfile Name:
> SharedPresentation.log
> 04/21/05 11:35:21 1452 Toolkit config.py:196 DEBUG Using
> GLOBUS_HOSTNAME=ag-display.cs.wisc.edu as set in the environment
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:257
> DEBUG Opened repository C:\WINNT\Profiles\ag-op\Application
> Data\AccessGrid\Config\certRepo
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:395 DEBUG Got repo.
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:397 DEBUG looking in system
> ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:401 DEBUG Getting cert:
> 1c3f2ca8.0
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:406 WARNING Not importing
> cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
> 45cc9e80.0
> cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
> d1b603c3.0
> cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
> f18fa857.0
> cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:410 DEBUG Init'ing globus.
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:734
> DEBUG Configuring standard environment
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:802
> DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.wisc.edu/CN=Michael Blodgett
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:873
> DEBUG Initializing environment with proxy cert for /O=Access
> dgett
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:907
> DEBUG Looking for identity (unused) None
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:892
> DEBUG Configuring for user proxy issued from /O=Access
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:895
> DEBUG Proxy C:\WINNT\Profiles\ag-op\LOCALS~1\Temp\proxy will expire
> 04/21/05 18:26:51
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:414 DEBUG Done with globus.
> 04/21/05 11:35:24 1452 EventClient eventclient.py:158 DEBUG Have
> callback handle _90725e02_p_callbackStruct
> 04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:727
> DEBUG Registering for events.
> 04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:735
> DEBUG Creating controller.
> 04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:810
> DEBUG Got Event: local load venue None
> 04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:1432
> DEBUG Method LocalLoadVenue called
> 04/21/05 11:35:27 1876 SharedPresentation sharedpresentation.py:1441
> DEBUG Got presentation:
> https://ivs.mcs.anl.gov:9006/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt
> 04/21/05 11:35:30 1876 DataStore datastore.py:1643 DEBUG Host
> ivs.mcs.anl.gov:9006, path
> 04/21/05 11:35:30 1876 DataStore datastore.py:1645 DEBUG Connect to
> 04/21/05 11:35:30 1876 DataStore datastore.py:1648 DEBUG Downloading
> into C:\WINNT\Profiles\ag-op\LOCALS
> ~1\Temp\presentation.ppt
> 04/21/05 11:35:30 1876 DataStore datastore.py:1655 DEBUG before
> connect reqest path
> /00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt, headers {}
> 04/21/05 11:35:31 1876 DataStore datastore.py:1657 DEBUG after connect
> reqest
> 04/21/05 11:35:31 1876 DataStore datastore.py:1659 DEBUG request sent
> to <pyGlobus.io.GSIHTTPConnection instance at 0x04E9EB20>
> 04/21/05 11:35:31 1876 DataStore datastore.py:1663 DEBUG response is
> <httplib.HTTPResponse instance at 0x021EA468>
> 04/21/05 11:35:31 1876 DataStore datastore.py:1664 DEBUG Request got
> status 200
> 04/21/05 11:35:31 1876 DataStore datastore.py:1677 DEBUG Got hdr
> 3336704
> 04/21/05 11:35:31 1876 DataStore datastore.py:1678 DEBUG ['Server:
> BaseHTTP/0.3 Python/2.3.4\r\n', 'Date: Thu, 21 Apr 2005 16:33:01 GMT\r\n',
> 'Content-type: application/octet-stream\r\n',
> 'Content-Length: 3336704\r\n']
> 04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1484
> ERROR Can not load file
> https://ivs.mcs.anl.gov:9006/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt 5
> Traceback (most recent call last):
> File "SharedPresentation.py", line 1481, in LocalLoadVenue
> self.viewer.LoadPresentation(tmpFile)
> File
> line 3749, in Open
> 04/21/05 11:35:43 1452 SharedPresentation sharedpresentation.py:762
> DEBUG Shutting down...
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:810
> DEBUG Got Event: local quit None
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1216
> DEBUG Method Quit called
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1234
> ERROR Exception destroying controller. This happens when using the x
> button in the top right corner. Not critical.
> File "SharedPresentation.py", line 1232, in Quit
> self.controller.frame.Destroy()
> File "C:\Python23\Lib\site-packages\wx\core.py", line 9344, in
> __getattr__
> raise PyDeadObjectError(self.attrStr % self._name)
> PyDeadObjectError: The C++ part of the SharedPresentationFrame object has
> been deleted, attribute access no longer allowed.
> 04/21/05 11:35:44 1452 EventClient eventclient.py:303 DEBUG Cancel
> pending callbacks
> 04/21/05 11:35:44 1948 EventClient eventclient.py:177 DEBUG Read
> Callback called arg=None handle=_08ef5c02_p_globus_io_handle_t result=(-1,
> 2, 'an I/O operation was cancelled') n=0
> 04/21/05 11:35:44 1948 EventClient eventclient.py:180 DEBUG
> readCallback gets failure in result: -1 2
> 04/21/05 11:35:44 1452 EventClient eventclient.py:309 DEBUG Free
> callback _90725e02_p_callbackStruct
> 04/21/05 11:35:44 1452 EventClient eventclient.py:315 DEBUG
> EventClient.Stop: closing socket
> 04/21/05 11:35:44 1452 EventClient eventclient.py:323 DEBUG
> EventClient.Stop: closing queue
