[AG-TECH] Quad Capture card performance
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Mon Apr 25 09:51:22 CDT 2005
No - it provides you with 4 video streams into your AG software.
Just as 4 separate Hauppage cards would.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the intended recipient only.
If you are not the intended recipient do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Natalia Costas Lago [mailto:natalia at cesga.es]
> Sent: 25 April 2005 15:50
> To: Osland, CD (Chris)
> Subject: Re: [AG-TECH] Quad Capture card performance
> So... the 4 inputs... is just like a multiplexer?
> From: "Osland, CD (Chris)" <C.D.Osland at rl.ac.uk>
> To: "Natalia Costas Lago" <natalia at cesga.es>
> Sent: Monday, April 25, 2005 4:44 PM
> Subject: RE: [AG-TECH] Quad Capture card performance
> The most obvious is that the Winnov card handles 4 inputs to
> the Hauppage's one! So 4 inputs take one PCI slot with a Winnov
> and 4 PCI slots with Haauppages.
> Cheers
> Chris
> Chris Osland
> Office tel: +44
> (0) 1235 446565
> 1235 446459
> Grid room tel: +44
> (0) 1235 445666
> Fax: +44
> (0) 1235 445597
> use of the
> on it or show
> it to anyone else,
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Natalia Costas Lago
> > Sent: 25 April 2005 15:37
> > To: ag-tech
> > Hi everybody,
> > Does anyone the advantages of the Spectra8/Winnov Videum 4400
> > over the
> > Hauppauge Impact VCB?
> > The hauppauge card is almost 5 times cheaper than the others.
> > Maybe there is
> > something am I missing?
> > Thanks in advance for ur help.
> > Kind regards,
> > Natalia.
> > From: "Natalia Costas Lago" <natalia at cesga.es>
> > To: "Derek Piper" <dcpiper at indiana.edu>
> > Cc: "ag-tech" <ag-tech at mcs.anl.gov>
> > Sent: Monday, April 25, 2005 4:05 PM
> > > Thanx a lot Derek!!
> > > That was enlightening!!
> > > From: "Derek Piper" <dcpiper at indiana.edu>
> > > To: "John Hodrien" <johnh at comp.leeds.ac.uk>
> > > Cc: "ag-tech" <ag-tech at mcs.anl.gov>; "Natalia Costas Lago"
> > > Sent: Monday, April 25, 2005 3:29 PM
> > >> Of course if the system you're installing on only supports
> > 32-bit x 33Mhz
> > >> slots (as many do) then you're not going to get a lot of benefit.
> > >> Natalia, what are the hardware specs on the capture
> machine you're
> > >> upgrading or rebuilding?
> > >> It's important to note too that however many PCI *slots*
> > you have, you
> > >> (normally) only have one PCI *bus*. And the TOTAL
> > bandwidth of that bus
> > >> is 32bit x 33Mhz = 132MBytes/sec. So however the cards are
> > arranged
> > >> (singly or quad) you're going to run into that same
> > bandwidth limitation.
> > >> Of course the quad capture card might be slightly more
> > efficient due to
> > >> it being the only card on the bus and thus eliminating bus
> > contention
> > >> between the capture cards.
> > >> To reiterate the math here?
> > >> 33000000 x 32 = 1056000000 bits/sec PCI max
> > >> = 132000000 bytes/sec PCI max
> > >> 1 frame (24 bit color) = (768 x 576 x 24 / 8 ) = 1327104 bytes
> > >> 25 fps = 33177600 bytes/sec
> > >> x 2 captures = 66355200 bytes/sec
> > >> x 3 captures = 99532800 bytes/sec
> > >> x 4 captures = 132710400 bytes/sec
> > >> Derek
> > >> John Hodrien wrote:
> > >>> On Mon, 25 Apr 2005, Natalia Costas Lago wrote:
> > >>>> We are about to purchase a Spectra8 capture card or
> > Winnov Videum 4400.
> > >>>> It's
> > >>>> a very good point not to have to use 4 PCI buses, that's
> > what I like
> > >>>> most of
> > >>>> both cards, however I am concerned to performance
> > issues, I mean, a PCI
> > >>>> bus
> > >>>> allows 132 Mbps more or less, and the Spectra8 delivers
> > 4 videostreams
> > >>>> at
> > >>>> 30fps 768x576 (it can be less, that's the worst case)
> > (similar values
> > >>>> for
> > >>>> the Videum 4400 card). So, it seems to me that the PCI
> > bus cannot
> > >>>> transmit
> > >>>> so much information, that means, does it drop frames?
> > Maybe I cant get
> > >>>> the
> > >>>> highest resolution at 30fps (25fps for the Winnov card)?.
> > >>> It won't be 30fps at 768x576 will it? That's PAL
> > resolution at NTSC
> > >>> frame
> > >>> rates. If you drop that to 25fps, the back of my
> > envelope looks like
> > >>> you'd
> > >>> indeed be rather close to 32 bit PCI limits. The 4400
> > supports 64bit
> > >>> PCI,
> > >>> thus solving that problem.
> > >>> jh
> > >> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> > >> IRI 323, School of Informatics
> > >> Indiana University, Bloomington, Indiana
