FW: [AG-TECH] passphrase fails
Steve Williams
S.Williams at ukerna.ac.uk
Tue Apr 19 14:59:48 CDT 2005
Thanks Thomas
Deleting:
> C:\Documents and
Settings\<you>\Application\Data\AccessGrid\Config\certRepo
didn't change anything, even with a new anonymous cert - but deleting
the whole tree from AccessGrid down and re-installing the toolkit did.
Previous re-installation had no effect so I assume that that tree, as
part of the user data, stays put during uninstall/install.
Sounds like you were right about something strange in there somewhere.
Managed to install my personal cert which I'd previously saved as well -
so even better.
Thanks to all for your help.
Cheers
Steve
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: 19 April 2005 18:36
> To: Steve Williams
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: FW: [AG-TECH] passphrase fails
> Steve:
> You should have certificates listed in the TrustedCACerts tab of the
cert
> manager. I
> suspect there is bad state in your certificate repository. I'd
recommend
> you do the
> following:
> - Exit any running AG software
> - Delete the following directory:
> C:\Documents and Settings\<you>\Application
> - Start the Certificate Manager
> - From the requests tab, request a certificate (you could request an
> anonymous cert, which
> will be immediately issued and available)
> - When the cert is ready, import it, and proceed as normal
> At the end of this, you should have multiple certificates listed on
the
> TrustedCACerts tab
> (Access Grid Developers CA, DOEGrids CA, ESnet Root CA, Anonymous).
If
> you don't, or if
> there is some other failure, let me know.
> Tom Uram
> Steve Williams wrote:
> > Thanks for those responses:
> > Nope, the cert has not expired, it is brand new and the dates on it
are
> > correct - I even got another one to check that it wasn't just the
cert
> > and that I hadn't made a typo in the passphrase.
> > This is a new install for me - it seems, though I may be wrong, that
the
> > main problem is that I should have something in the Trusted CA tab
of
> > the cert manager - I have nothing.
> > Does that spark any lights?
> > Cheers
> > Steve
