[AG-TECH] GetData() problem in wxPython shared application
sjj at maths.uq.edu.au
Thu Apr 14 09:55:01 CDT 2005
Hello Steve,
I forgot to mention that you can create and destroy application sessions
atomatically in the venue. Then you don't have to open the venue client to
add/remove a session.
To create an application session (using the venue soap interface):
from AccessGrid.Venue import VenueIW
venue = VenueIW("https://localhost:8000/Venues/default")
appDesc = venue.CreateApplication("Shared App Name",
"Shared App Description",
"application/x-ag-shared-app")
appUrl = appDesc.uri
To destroy an application session:
venue.DestroyApplication(appDesc.id)
Hope this helps,
Susanne
On Wed, 13 Apr 2005, Susanne Lefvert wrote:
> Hello Steve,
> You will have to manually delete the data when the last client leaves, or
> remove the application session like you mentioned.
> Susanne
> On Wed, 13 Apr 2005, Stephen Jeffrey wrote:
> > Thanks Susanne. If I initialise the variable before
> > calling GetData(), and then test using
> > if self.file:
> > it seems to work OK.
> > I now have another problem - the data does not get deleted
> > from the application service when all copies of the application
> > are terminated. The very first time the application is started,
> > it reports there is no data stored, as it should. However if
> > I terminate the application and then restart it, it reports
> > that there is existing data. The only way to delete the data
> > appears to be to delete the shared app from the venue client
> > window, and then add the shared app again (using the Start
> > Application Session option under the Venue menu in the venue
> > client window). Is this normal behaviour, or do I have to
> > somehow manually delete the data when the application terminates?
> > cheers
> > steve
> > > This works for me:
> > > self.file = None
> > > # Get current state
> > > self.file = self.sharedAppClient.GetData("file")
> > > if self.file:
> > > # do stuff
> > > else:
> > > print "data does not exist..."
> > > Which platform?
> > > Susanne
> > >>Hi All,
> > >>I am writing a shared application using wxPython. The application
> > >>is to query if there is any shared data present when it starts.
> > >>ie. if another copy of the application is already running and has
> > >>sent some data using sharedAppClient.SetData(), when the second
> > >>copy of the application starts it should obtain the data stored
> > >>by the first copy.
> > >>How can I query if there is any shared data already present?
> > >>I have tried:
> > >>d = self.sharedAppClient.GetData("data")
> > >>if len(d) > 0:
> > >>and other variations such as:
> > >>if d != 0:
> > >>and
> > >>if d != None:
> > >>but it appears as though GetData() is returning junk - when the
> > >>first copy of the application starts there should not be
> > >>any shared data present, but it returns non-zero data.
> > >>Is there some way to overcome this, or do I have to somehow
> > >>get the first instance of the application to "initialise"
> > >>the shared data.
> > >>cheers
> > >>steve
> > >>Dr Stephen Jeffrey
> > >>Advanced Computational Modelling Centre
> > >>University of Queensland
> > >>St. Lucia Queensland 4072 Australia
> > >>Phone: +61 (7) 3365 6130
> > >>Fax: +61 (7) 3365 6136
> > >>Email: sjj at maths.uq.edu.au
> > >>Web: http://www.acmc.uq.edu.au
