[AG-TECH] ask for help about connecting to the vennue
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 13 09:28:00 CDT 2005
zhyuwang:
The traceback lines following the error messages you sent are an important part of
understanding what went wrong. If you send these, we'll be better able to help you.
Here are two tips that may help:
- Version 2.2 had some stability issues; I'd recommend that you use the 2.3 version instead.
- Make sure the time on your computer is set accurately. Preferably, you'd synch it to an
NTP server.
Tom
zhyuwang wrote:
> After installing AGTK2.2,I tried to connect to the vennue https://vv2.mcs.anl.gov:9000/Venues/default
> .But it failed.In the VenueClient.log ,I find the errors:
> ERROR EnterVenue: failed
> Traceback (most recent call last)
> ERROR EnterVenue: globus tcp exception: ('a system call failed (Unknown error)',)
> ERROR SOAP fault occurred
> Traceback (most recent call last).
> I cann't understand the error .can any one help me tell me why has those errors,and how i can conque these errors.
> thanks in advance!!
