[AG-TECH] iTuner Spectra 8 and IDS Falcon Quattro under Windows XP whining
JonJohansson at cnsmail.srv.ualberta.ca
Thu Sep 30 12:45:18 CDT 2004
I sent this to the list with a bunch of images attached and
it didn't make it through (probably best). I've edited it
a bit and the long version is now on a web page (the URL is
below).
I have both an IDS Falcon Quattro and an iTuner Spectra 8
which I'm experimenting with under WinXP on different machines.
They both behave pretty much the same way for me (and not
satisfactorily) so first I'm wondering if anyone has a configuration
running WinXP that can actually deliver 3 or 4 good quality streams.
If so could you let me know the magic in terms of hardware/software/
registry-hacks that you used to make it go (at least for the Spectra)?
Secondly, I know that there are a number of people who run Linux
with the iTuner card: are there any tricks to getting 4 streams
out under Linux? Is a 2.6 kernel compiled with VfL and the
0.9.something version of the bttv driver enough or is there more to
make it work? I know the Falcon works (for 3 streams anyway) with
the bttv 0.7.something drivers and a 2.4 kernel.
The long description of what is happening can be found at:
http://tyr.cns.ualberta.ca/VideoCapture/VideoCapture.html
and some images of the steps that I describe.
Basically under XP, I add 4 video producers and I get 2 good color
streams, one jumpy b/w stream and vic eventually gives up on trying
to connect to the video source for one input. The b/w stream is
always the input labelled Vin 1 on the Spectra card and the one that
chokes is always Vin 4.
I'd appreciate any help in getting all 4 streams working on these
(at least the Spectra) cards.
Yes, I should have got a Videum ...
Jon.
Jon I Johansson * Research Computing Support
jon.johansson at ualberta.ca * Computing and Network Services
Tel.: (780) 492-9304 * University of Alberta
Fax.: (780) 492-1729 * Edmonton, Alberta, CANADA
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040930/021c3e8a/attachment.htm>
