[AG-TECH] Gnome launchers in FC2
Kenison, Christopher M
CMKenison at mtech.edu
Thu Sep 30 10:10:35 CDT 2004
How can i be removed from the mailing list? Thanks
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov on behalf of Douglas Kosovic
Sent: Tue 9/28/2004 1:26 AM
To: ag-tech at mcs.anl.gov
Cc:
Subject: Re: [AG-TECH] Gnome launchers in FC2
"Jim Miller" <millerjw at psc.edu> wrote:
>I am having problems with the launchers in Gnome. If I open an xterm or a
>gnome-terminal and run Service Manager by physically typing
>AGServiceManager.py everything works fine. However, If I try to run
>servicemanager from the menu items or create a launcher myself, the
>AGServiceManager will run and listen on port 11000, but as soon as the
>VenueClient tries to communicate with the ServiceManager, the terminal
>window disappears and the AGServiceManager.py script dies.
I've put up a new version of the Fedora AccessGrid 2.3 RPM which fixes the
above problem (with the Debug versions of the Gnome menu entries which bring
up a terminal). The new RPMs can be found at:
http://www.itee.uq.edu.au/~agn/ag_fedora/
With the Debug version menu entries, I've also added a 2 second delay before
the terminal disappears, to give a bit of a chance of reading any error
messages. There were some other minor fixes to other menu entries, like the
"Node Service" menu entry which is now working.
The updated FC2 RPMs were released last week, and the FC1 just yesterday.
I'm just making this announcement for those people not using up2date.
If you are doing an update rather than an install, you will need to
re-register the system shared-applications by issuing the following as root:
agpm.py --post-install(This is a result of a bug in
AccessGrid-2.3-3.i386.rpm postun step)Doug.
