[AG-TECH] screens/projectors set up
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Mon Sep 27 04:34:27 CDT 2004
The main 'trick' is to set the background to black. Then, when
two images don't quite abut, or overlap, there is no double
intensity or gap in the background. Then it's just a matter of
normally arranging the windows so they don't span projectors.
Once you get into edge-blending (the term that describes the handling
of overlapping areas) you are into SERIOUS amounts of money for
hardware: I haven't seen a software solution. You can do a bit
with the intensity control on each projector, but there will usually
be a bit of a mismatch with commodity level projectors.
Another thing I do is run our 1024x768 (native) projectors with
1280x960 signals. This gives a dramatic increase in the number of
pixels (2 such projectors have more pixels than 3 1024x768 projectors)
and makes it much easier to fit 3x3 medium size windows on each
projector, without using the shift-m trick which crops edges off
the windows (maybe losing vital bits of some carefully judged
framing). For AG images the results are fine; for PowerPoint
etc. they are acceptable.
HTH
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of
the intended recipient only. If you are not the intended recipient
do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Natalia Costas Lago
> Sent: 25 September 2004 17:18
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] screens/projectors set up
> Hi everybody,
> We are in the latest stage in building our node. The problem
> we have right
> now is how the projectors can't be tunned so the transition from one
> screen to the next is smooth (it seems to be very difficult from the
> technicians to tune the position and the color). I wonder is
> there is some
> trick AG users have to fix this.
> Maybe the screens overlap and there is some software that handles the
> overlapping area?
> We have another problem as the central projector seems to
> have a slightly
> different brightness (even though the settings are the same for the 3
> projectors). But we havent tried to fix this so far.
> Any help about this issue is greatly appreciated.
> Kind regards,
> Natalia.
> Natalia Costas Lago
> mailto: natalia at cesga.es
> Centro de Supercomputacion de Galicia (CESGA)
> Center for High Performance Computing
> Avenida de Vigo, s/n Campus Sur
> 15705 Santiago de Compostela - SPAIN
> Tel: +34 981 56 98 10
> Fax: +34 981 59 46 16
> http://www.cesga.es/
