[AG-TECH] AG2.3 shared applications problems
Hengzhi Zhong
hzhong at ncsa.uiuc.edu
Thu Sep 23 10:15:23 CDT 2004
Previously I have installed 2.1.2b. I uninstalled the toolkit 2.1.2b
before I installed 2.3.
I went to C:\Documents and
Settings\<user>\ApplicationData\AccessGrid\Config\ApplicationDatabase and
renamed it, but this didn't work. So I tried looking for the
SharedBrowser.log file from C:\Documents and Settings\<user>\Application
Data\AccessGrid\Logs and I don't see a log file for sharedbrowser. There
are log files for shared presentation, shared rasmol, and shared
questiontool, but no sharedbrowser.
By the way, SharedPresentation works. So, among the included shared
applications (shared browser, shared application, shared questiontool),
only shared browser does not open.
Any suggestions?
Hanna
At 04:31 PM 9/16/2004, Susanne Lefvert wrote:
>On Thu, 16 Sep 2004, Hengzhi Zhong wrote:
> > Hello all,
> > I have installed AG2.3 for a PIG. The PIG is on windows
> > XP. SharedBrowser, SharedQuestionTool, and PowerPoint are already
> included
> > in the shared applications. However, when I tried to open SharedBrowser,
> > nothing shows up. I could open SharedQuestionTool just fine.
> > Later I installed SharedRasmol. I could add SharedRasmol to the
> > applications, but when I clicked on it to open, nothing showed up.
> > It seems to that other than SharedQuestionTool, none of the shared
> > applicatiosn can open on the PIG. Why is that? What should I do?
>Did you have an earlier version of the toolkit installed before you got
>2.3? Sometimes, old shared applications are causing newer ones to fail.
>You could try renaming C:\Documents and Settings\<user>\Application
>Data\AccessGrid\Config\ApplicationDatabase and see if that
>helps. If that does not work, please send me your SharedBrowser.log file
>from C:\Documents and Settings\<user>\Application Data\AccessGrid\Logs.
> > Also, what is the difference between Open and Open for All? When should I
> > use Open and when should I use Open for All?
>If you select Open for All, every participant in the venue will get an
>invitation to join the application session. If you select Open, only
>your client will start.
>Regards,
>Susanne
