[AG-TECH] recording an agn session
    Ivan R. Judson
    judson at mcs.anl.gov
    Fri Sep 17 12:58:51 CDT 2004
That's a good point, in order to do this in the AG you'd have to write some
code that would basically filter the streams out of a session -- we have
this in the works now (a Video Stream Selection Service) -- and if you can
describe how you would like this to work we can consider it as a use
case/requirements dicussion of the service.
Great idea.
--Ivan
> -----Original Message-----
> From: Kasper Peeters [mailto:kasper.peeters at aei.mpg.de]
> Sent: Friday, September 17, 2004 12:42 PM
> To: judson at mcs.anl.gov; ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] recording an agn session
> > We have not worked on a solution for a single stream of
> video because
> > that's outside the expectations of what we're trying to
> build. Can you
> > elaborate why you would want only one stream?
> Because very often only one or two video streams are really
> relevant, the other ones showing people eating sandwiches or
> sleeping on their desk ;-)
> RAT saves the audio just fine, I'm only missing a solution
> which takes care of one or two of the VIC video streams
> (multiplexing can be done later).
> Kasper
