[AG-TECH] WinXP sp2?
    Todd Zimmerman
    toddz at sfu.ca
    Thu Sep 16 14:54:02 CDT 2004
AG seemed to work on XP-SP2; however, the biggest issue I found is there
seems to be no way of allowing a block of ports through the XP firewall.
  From what I can see, each port must be individually allowed through
the firewall....
While most of the connections are 'firewall friendly'... the streams use
RTP port pairs - so you have to tell the firewall about the additional
connections.
Its not really a practical solution to enter the ports individually if
the venueserver you are connecting to selects random ports from a range
50000 to ~65000.
I've only preliminarily investigated this... however this problem seems
to be confirmed at this article:
http://www.winnetmag.com/Windows/Articles/ArticleID/43085/pg/3/3.html
If anyone has a work around I'd be interested to hear!
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Randy Groves wrote:
> I guess that we can infer from Ivan's comments about 2.3 on sp2 that
> this is considered a 'supported' environment?
> Any issues/pointers with setup of the firewall and/or other of the
> security features?
> -randy
