[AG-TECH] BridgeServer
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Sep  2 14:02:57 CDT 2004
It looks like you recreated the venues without static addressing, so
there are no streams in the venue to bridge.  If someone enters the
venue and wants to send audio or video, streams would be allocated and
the bridge server should start bridges for those streams.  This is,
however, different than you worked previously.  If you set up your
venues for static addressing, the bridges should get started when you
start the bridge server, as previously.
As for the bridge config file, you can specify either a venue server, or
individual venues; specifying both would be redundant.
Tom
Jeremy Mann wrote:
> Something happened to our bridge server and its not loading anymore. I
> modified our cfg file from the change to 2.2 and I recreate our venues
> with the newer 2.2 VenueManagment software.
> Running the BridgeServer does not show anything like the previous one did.
> All I get is this:
> ag at ag1:~$ BridgeServer.py -c BridgeServer-ag22.cfg
> No output at all. Running it in debug mode, interestingly gives me this:
> 09/02/04 12:33:22 16384 Toolkit     BridgeServer.py:222 INFO  AddVenue:
> url =
> https://ag1.v19.uthscsa.edu:8000/Venues/000000fec00c55bc0081006f004500a718e
> 09/02/04 12:33:24 16384 EventClient     EventClient.py:166 DEBUG Have
> callback handle _a04d2f08_p_callbackStruct
> 09/02/04 12:33:24 81926 Toolkit     BridgeServer.py:558 INFO  Method
> Venue.RunQueueThread called
> 09/02/04 12:33:24 16384 Toolkit     BridgeServer.py:222 INFO  AddVenue:
> url =
> https://ag1.v19.uthscsa.edu:8000/Venues/000000fe062acde90081006f004500a75ac
> 09/02/04 12:33:25 16384 EventClient     EventClient.py:166 DEBUG Have
> callback handle _c02b2608_p_callbackStruct
> 09/02/04 12:33:25 131081 Toolkit     BridgeServer.py:558 INFO  Method
> 09/02/04 12:33:36 98311 Toolkit     BridgeServer.py:588 INFO  Done sleeping
> 09/02/04 12:33:36 98311 Toolkit     BridgeServer.py:591 INFO  Send heartbeat
> 09/02/04 12:33:37 147466 Toolkit     BridgeServer.py:588 INFO  Done sleeping
> 09/02/04 12:33:37 147466 Toolkit     BridgeServer.py:591 INFO  Send heartbeat
> Maybe my configuration file is wrong. I couldn't understand the
> BridgeServer documentation for 2.2. Do you HAVE to list all of your rooms
> AND have a VenueServer line? Or can you do it the old way and just list
> the VenueServer. Its all very confusing. Here's my file:
> [BridgeServer]
> location = University of Texas Health Science Center at San Antonio
> qbexec = /usr/bin/QuickBridge
> name = UTHSCSA Bioinformatics Bridge Server
> # Biochemistry room
> [https://ag1.v19.uthscsa.edu:8000/Venues/000000fec00c55bc0081006f004500a718e]
> type = Venue
> # Bioinformatics room
> [https://ag1.v19.uthscsa.edu:8000/Venues/000000fe062acde90081006f004500a75ac]
> type = Venue
> #[https://ag1.v19.uthscsa.edu:8000/VenueServer]
> #type = VenueServer
> As you can see here, I have 2 rooms listed and a commented VenueServer
> line. I've tried it both ways, just a VenueServer line then VenueServer
> line AND two rooms. Both have the same problems. Can anyone help?
