[AG-TECH] Re: How to bypass Globus' security in AccessGrid
David G Mills
dgm at ecs.soton.ac.uk
Thu Sep 2 06:43:51 CDT 2004
yes i've seen that, but haven't tried to follow it.
what I get now after using those rpm's is this:
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
(VenuseClient.py:29713): Gtk-WARNING **: cannot open display
Is this what you see? Any ideas?
Dave.
On Thu, 2 Sep 2004, Socrates Varakliotis wrote:
> There's also this, not sure if it helps:
> http://www.accessgrid.org/agdp/howto/fedora2install.html
> From: "David G Mills" <dgm at ecs.soton.ac.uk>
> To: "Socrates Varakliotis" <S.Varakliotis at cs.ucl.ac.uk>
> Cc: "Piers O'Hanlon" <P.OHanlon at cs.ucl.ac.uk>
> Sent: Thursday, September 02, 2004 12:11 PM
> Subject: Re: How to bypass Globus' security in AccessGrid
> > yes I saw that... it would seem to be some fedora related bug in gtk, or
> > possibly AGTK using somthing in gtk that is private. I am install wxGTK
> > and wxPython from RPM as I had no problems using these last time.
> > Dave.
> >> > I'll try the --insecure switch in a sec. When you say it hasn't worked
> >> > for
> >> > you, do you get errors or does it still use the GSI functions?
> >> No, I get no errors, both server and client start fine. However, the
> >> client pops up a message saying it cannot find the server. Will be
> >> looking at this closer today.
> >> Eric's message says that the EventService and TextService are not fully
> >> "insecure" and still require globus, proxies, etc.
> >> > Hi Socrates,
> >> > There is an --insecure option for both the VenueClient and
> >> > VenueServer.
> >> > The insecure option uses http for soap communications and
> >> > considerably speeds up actions such as entering a venue. But,
> >> > with the current toolkit, there are a few AGTk components (such
> >> > as the EventService and TextService) that need to be be modified
> >> > to avoid all need for security, so globus and a globus proxy are
> >> > still required at this time.
> >> > Eric
