[AG-TECH] Simple question.
Thomas D. Uram
turam at mcs.anl.gov
Wed Sep 1 15:29:46 CDT 2004
Jim:
As of 2.2, the stream name should appear in the title of the sending vic
windows, and in the title of the per-stream windows ("on the wall"). In
the latter case, the title is <ProfileName>(StreamName) (e.g.,
NDSU(Audience)).
Note that changes to the streamname parameter show up only after the
producer vics have been stopped and started, since vic doesn't allow us
an option to change that info on the fly.
If you're not seeing the stream names show up this way, and you're using
2.2 or later, you should file a bug.
Tom
Jim Senechal wrote:
> I know the answer will probably be way to easy and make me feel ashamed for
> not finding it sooner, but, here goes. I cannot find where to change the
> name of your streams so that the window that shows up on the wall says what
> the stream is, ex. NDSU Audience, NDSU Presenter, etc... I used the manage
> my node to change the stream name so that it shows up on the vic, but I
> haven't found where to input the names for the display windows? Thanks.
> Jim
> Jim Senechal, Digital Conference Specialist
> North Dakota State University
> Fargo, ND 58105
> Phone # (701)231-6247
> E-mail: jim.senechal at ndsu.nodak.edu
