[AG-TECH] Video capture help?
    Thomas Uram
    turam at mcs.anl.gov
    Thu Oct  7 12:22:37 CDT 2004
Jim:
2.3 detects vfw drivers available on your machine, using the same code
that vic does.  It should, therefore, show you the same list of devices
that vic shows.  The wdm driver you see is a mapper for applications
that only use vfw drivers; you can map one of your devices through it
using "Configure on transmit" in vic, and then selecting the device you
want to use.  Unfortunately, you can't use multiple devices this way
(unless you 'configure on transmit' each device with every venue switch).
If you have vfw drivers installed, 2.3 will detect and use them fine.  I
know there are vfw drivers for the Winnov Videum 4400 and the Osprey
cards, and I've seen those work fine.  I haven't found vfw drivers for
the Hauppauge cards (or the iTuner Spectra8, for the sake of saying so).
Tom
Jim Senechal wrote:
>Hello all,
>I am trying to set up my video capture machine to run off of Windows XP.
>I'm sorry if this has been discussed before, I am just now running into the
>problem and need a helping hand.  I have the standard old Hauppauge capture
>cards in my computer (878 chipset), I downloaded the drivers, installed
>them, and XP seems happy with the cards.  I install all the AG 2.3 software
>and when I go to run the node setup wizard the only choice I get is Windows
>wdm image capture?  None of the 4 Hauppauge cards show up on the video
>capture machine?  Did I miss a step, am I doing something wrong?  Some
>little trick I don't know about?  Any help would be appreciated.  Thanks.
>Jim
>Jim Senechal, Digital Conference Specialist
>North Dakota State University
>Fargo, ND  58105
>Phone # (701)231-6247
>E-mail:  jim.senechal at ndsu.nodak.edu
