[AG-TECH] VenueVNC
Randy Groves
randy.groves at boeing.com
Wed Oct 6 11:59:27 CDT 2004
So you mean that in order for VenueVNC to work on Windows there needs to be
a server and viewer running on the same machine? Sorry, I feel a bit dense
about this - I use VNC all the time, and presumed that what I would be
doing with the VenueVNC app was to start up a viewer that I could point to
an arbitrary venue server out there. Is this an incorrect assumption? Or
is this the first step towards setting up a service that a node presents to
the world?
If there's documentation that I should go and read (more than the readme)
please feel free to point me in that direction.
-randy
At 08:39 AM 10/6/2004, Ivan R. Judson wrote:
>but you need to know what to point it at, which is why you can't start it
>without a server being present.
>--Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Groves
> > Sent: Wednesday, October 06, 2004 10:33 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] VenueVNC
> > Thanks - but it's the client (read viewer) that I'm trying to
> > start. I realize that if I want to serve up a Windows
> > screen, I'll either have to wait or hack the code.
> > -randy
> > At 06:35 PM 10/5/2004, Douglas Kosovic wrote:
> > >Hi Randy,
> > >>OK - feel free to slap me upside the head if I've missed something,
> > >>but I don't see how one is supposed to fire up the VenueVNC
> > >>application. It registers just fine, but since it is marked
> > >>'startable = 0' it doesn't show up in the list of applications that
> > >>can be added. I don't see it in the Windows Start menu
> > anywhere (is
> > >>it supposed to be there?). I'm guessing it's not intended
> > to be run
> > >>from a command window, as I've so far not been able to fire it up
> > >>there either (errrors, etc.). The readme doesn't help.
> > >VenueVNC isn't one application, it's two, a client and a server.
> > >The README file in CVS says:
> > > There is no Windows VenueVNC server at this time.
> > >So the VenueVNC server needs to be started on the Linux command-line.
> > >Doug
