[AG-TECH] Hauppauge WinTV Cards not being recoginized by VIC
Thomas D. Uram
turam at mcs.anl.gov
Tue Nov 23 14:33:40 CST 2004
Todd:
Node Management detects vfw drivers because that's what is used by vic. AFAIK, there are
only WDM drivers for these cards, so the only choice you get is the VfwWdm compatability
driver, which gives you access to one card at a time.
All four of the cards can be used in Linux, if you're flexible about the platform you use.
Tom
Todd Reed wrote:
> I have four Hauppauge WinTV cards in a video machine. WindowsXP
> recoginizes the cards, and each card is working through the Hauppauge
> software. But, when I try to configure using the Mode Management(NM),
> the NM only sees one Microsoft WDM Image Capture Device.
> Any Suggestions?
> _________________________________________________________________
> Don’t just search. Find. Check out the new MSN Search!
> http://search.msn.click-url.com/go/onm00200636ave/direct/01/
