[AG-TECH] 2.3 installation (video producer problems)
Mike Elmore
mwelmore at lbl.gov
Fri Nov 12 12:54:55 CST 2004
I hope that this isn't a fact. We are just using that WS# box for the video
producer. Did you have similar problems with node manager unable to find the
video capture devices?
Mike
"Victor M. Babson, Jr." wrote:
> If you must use RHEL WS3, then I would have to recommend that you drop back
> to 2.2 and put up with the bugs. I spent weeks trying to get 2.3 on WS3.
> When I switched to Debian, however, I was up in minutes! 2.3 just will not
> work on RHEL WS3 afaict.
> --Vic
> From: <MWElmore at lbl.gov>
> To: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, November 10, 2004 2:18 PM
> Subject: [AG-TECH] 2.3 installation (video producer problems)
> > We have been trying to upgrade to 2.3 with mixed results. The display
> machine that supports audio and the video consumer is fine. The machine
> that supports the video producer is not. We have installed red hat WS3 for
> the os and we used FC1 for the ag2.3 system. When we try to add the service
> we only see x11 as being available. We see the same thing on the video
> producer machine if we try to run node mangement from there. Any help will
> be appreciated.
> > Thank you,
> > Mike Elmore
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041112/693d5d4b/attachment.vcf>
