[AG-TECH] Node setup Wizard
Derek Piper
dcpiper at indiana.edu
Fri Nov 5 12:31:55 CST 2004
Patrick,
I agree with David. Use 2.3, I had an amazingly easier time getting
things to work, not to mention 2.3 is a usable speed (2.2 was slow as
molasses for me for some reason).
For simplicity and to avoid confusion I would uninstall previous
versions as much as possible.
For Windows, get and install the following:
AGTk-2.3-Py-2.3.exe
ActivePython-2.3.2-232-win32-ix86.msi
wxPythonWIN32-2.5.1.5-Py23.exe
For RedHat, get and install all the RPMS from here:
http://www.itee.uq.edu.au/~grangenet/ag_fedora/FC1/stable/RPMS/
You should probably read these notes too:
Yes, it says Fedora Core1, but they work with no problems in RedHat9.
I'd hope it'd work on Enterprise too. If they're dedicated machines you
could always go the Gentoo route too, since it appears to be 'officially
supported' by ANL.
I have a RedHat and XP machine for our node and it worked great. I had
the whole lot running in an hour.
Derek
Patrick Johnson wrote:
> I am trying AGTk 2.2 I thought that 2.2 being one version behind the
> latest would provide me with the most documentation and stability.
> I'm on a tight deadline to get this up and running. I'm looking for the
> easiest and most documented path to getting a Access Grid Node up and
> running.
> I have two RedHat Enterprise Linux computers and one XP Pro computer.
> Do I need to uninstall everything and start over? What version should I
> go with?
> Patrick
> -----Original Message-----
> From: David McNabb [mailto:mcnabb at umd.edu]
> Sent: Friday, November 05, 2004 5:36 AM
> To: Patrick Johnson
> Subject: Re: [AG-TECH] Node setup Wizard
> I hope you meant 2.3 or 2.1.
> IMHO, 2.2 was a mess and should be avoided.
> 2.3 is much more stable and functional.
> Go directly to 2.3 or stay at 2.1.
> --David McNabb
> From: "Patrick Johnson" <pjohnson at imsav.com>
> To: <ag-tech at mcs.anl.gov>
> Date: Thu, 4 Nov 2004 15:36:35 -0800
> Subject: [AG-TECH] Node setup Wizard
> I'm having trouble running the Node Setup Wizard under AGTk 2.2
> I have two Linux systems running RHEL v.3 (audio and video capture) and
> one Windows XP Pro system for my display.
> I first started the AGServiceManager.py on each of the Linux systems.
> Each system replies with a "bound to port 12000" and no errors.
> The XP system also starts the Service Manager Service with no errors but
> when I start the Node Setup Wizard I get an error "Can not start Node
> Setup Wizard". There are no other error messages and nothing in the
> event viewer. Has anyone else had this problem?
> Thanks,
> Patrick Johnson
> Integrated Media Systems
> 1260 N. Fee Ana
> Anaheim, CA 92807
> office: 714-579-4100
> cell: 714-225-0666
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
