[AG-TECH] Hooking up Microphones to a Polycom (EF2241)
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Mon May 24 05:14:33 CDT 2004
Just use the Phoenix connectors that come with the ClearOne to make up
Phoenix to XLR short leads (use male or female XLRs as required for inputs
or outputs).  Then you can use any normal (i.e. XLR-based) gear with the
ClearOne and can use normal equipment on other gear afterwards.  If you
use up the Phoenix connectors on the mics etc., you can't use any other
gear on the ClearOne and can't use the modified equipment with anything
else.
Cheers
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf
Of Victor M. Babson, Jr.
Sent: 21 May 2004 16:46
To: AG-TECH
Subject: [AG-TECH] Hooking up Microphones to a Polycom (EF2241)
I wonder if anyone can advise me as to how they hooked up a standard mike
(3-prong) connection to the Polycom?
The polycom looks like it takes a "straight wire-through".
If anyone has a part #, description of what they did, etc.  I would greatly
appreciate your help.
TIA
--Vic
Management Info. Specialist
University of Georgia
Biochemistry & Mol. Biology
B203 Life Science Bldg.
Athens, GA  30602
(706) 542-6565
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040524/b1c15d98/attachment.htm>
