[AG-TECH] Hooking up Microphones to a Polycom (EF2241)
    Victor M. Babson, Jr.
    vbabson at secsg.uga.edu
    Fri May 21 17:01:18 CDT 2004
Thanks for all the replies.
Actually,
The easiest/quickest connection method was to cut the mike wire, strip it,
and feed the 3 wires into the 3-wire conductor block (Phoenix connector).
Works like a charm!
Thanks again for all the replies.  Now I'm off to figure out how I am going
to feed the computer output through the Polycom unit...
--Vic
----- Original Message -----
To: "Victor M. Babson, Jr." <vbabson at secsg.uga.edu>
Cc: <ag-tech at mcs-anl.gov>
Sent: Friday, May 21, 2004 2:10 PM
Subject: Re: [AG-TECH] Hooking up Microphones to a Polycom (EF2241)
> This does not require anything special.  Just a XLR jack with short
> wires to go into the screw terminals in the Phoenix connector on the
> Polycom unit.  Keep the pigtail short, for electrical noise reasons, or
> use shielded microphone cable, but it is relatively easy to do. No mixer
> or other hardware is needed, as the Polycom is a good mixer in it's own
> right, and is capable of supplying phantom power for electret
> microphones like the ones typically used for Grid applications.  Part
> number for a panel mountable jack from Newark Electronics
> (http://www.newark.com) is 46F8556.  Connect XLR pin 1 to ground, XLR
> pin 2 to +, and XLR pin 3 to -, as described in the reference manual.
> Sincerely
> James Fait
> SER-CAT
> On Fri, 2004-05-21 at 10:45, Victor M. Babson, Jr. wrote:
> > I wonder if anyone can advise me as to how they hooked up a standard
> > mike (3-prong) connection to the Polycom?
> > The polycom looks like it takes a "straight wire-through".
> > If anyone has a part #, description of what they did, etc.  I would
> > greatly appreciate your help.
> > TIA
> > --Vic
> > Management Info. Specialist
> > University of Georgia
> > Biochemistry & Mol. Biology
> > B203 Life Science Bldg.
> > Athens, GA  30602
> > (706) 542-6565
> James Fait <fait at anl.gov>
