[AG-TECH] question about gpt RPM installation
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Tue May 18 01:04:06 CDT 2004
Hi Joseph,
> I have a question about gpt installation.
> In fact, I'm opening the src.rpm using Debian command alien -t then I read
> the *.spec file to see how it works and reproduce quite the same thing.
> However, I have been suprised by the gtp spec file from gpt-1.0-2.src.rpm
> . Indeed, the %build is :
> %build
> export GPT_LOCATION=%{buildroot}%{prefix}
> ./build_gpt
> with
> %define name            gpt
> %define version         1.0
> %define prefix          /usr/lib/%{name}
> %define buildroot       /var/tmp/%{name}-%{version}
The %{buildroot} directory is just a temporary location during an rpmbuild
for storing files which will end up in the final RPM.
It's the %files step which indicates which files are included in the RPM and
where they will be installed to.
> When I do it, all the installation files are installed in
> /var/tmp/gtp-1.0/usr/lib/gpt and there is nothing else about GPT, I think,
> on the hard disk.
When the gpt RPM is installed, the files are located in /usr/lib/gpt and
/etc/profile.d/.
> Do I have to understand that this package is installed in
> /var/tmp/gpt-1.0/usr/lib/gpt even if the GPT_LOCATION, setup at the end of
> the script, is /usr/lib/gpt ? Is it right ?
No. You might want to see the RPM-Howto to see which sections of a RPM SPEC
file have an impact on the RPM building process and which have an impact on
the final RPM when it is actually installed, see:
  http://www.rpm.org/RPM-HOWTO/
I don't know much about Debian's alien, perhaps it was designed mostly for
binary RPMs rather than SRC-RPMs?
Cheers,
Doug
