[AG-TECH] Image quality
    Brian Corrie
    bcorrie at sfu.ca
    Thu May 13 14:45:32 CDT 2004
Hi Natalai,
No one has suggested this yet, but you might want to look at whether you
are using the right setting in terms of PAL/NTSC etc. If xawtv looks
good but vic does not this implies that is an application level problem,
not a camera problem. If you don't have the right video settings we find
that the image becomes almost a greyscale image etc. This might be the
problem.
Brian
Natalia Costas Lago wrote:
> Thank you for the hints, in xawtv the image is not that bad, but in VIC it's
> terrible (colors and definition), it doesnt make much difference to increase
> quality and bandwith to the maximun. I was wondering wich tricks or codecs
> do people use. Am I wrong in my thought about h261 being the only codec
> available to AG2.1.2?
>>Nothing about your equipment, of itself, should cause any major
>>image quality deterioration.  Of course, if the camera has been
>>used before and left pointed at a bright source for a long time,
>>say in a surveillance role, it could be the problem.  Equally if
>>someone has set up the monitors for a particular application, they
>>could be the problem.  If you have a decent AV department around,
>>you could try to eliminate the camera as the problem by plugging
>>in a video signal generator instead, with it set to colour bars,
>>and see how they come out - they should really shine on a PC
>>monitor.  If they do, then try a different camera.  If they don't, look
>>at the display side of things.  Make sure you don't have any
>>excessive cable runs - many cameras don't have very powerful output
>>drivers and the first thing to go can be colour.  Also check you
>>are using proper video cable from camera to capture card - an
>>underspecified cable will lose high frequencies (say above 3 MHz)
>>more than lower ones, and so reduce the colour information.
>>Cheers
>>Chris
>>____________________________________________________________________
>>Chris Osland                                               Office tel:
>>+44 (0) 1235 446565
>>Digital Media and Access Grid                          Medialab tel:
>>+44 (0) 1235 446459
>>BIT Department                                     Access Grid room
>>tel: +44 (0) 1235 445666
>>e-mail:   C.D.Osland at rl.ac.uk
>>Fax: +44 (0) 1235 445597
>>CLRC Rutherford Appleton Laboratory (Bldg. R18)
>>Chilton, DIDCOT, Oxon OX11 0QX, UK
>>[The contents of this email are confidential and are for the use of the
>>intended recipient only.
>>If you are not the intended recipient do not take any action on it or
>>show it to anyone else,
>>but return this email to the sender and delete your copy of it.]
>>>-----Original Message-----
>>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
>>>Behalf Of Natalia Costas Lago
>>>Sent: 13 May 2004 08:43
>>>To: ag-tech at mcs.anl.gov
>>>Subject: [AG-TECH] Image quality
>>>Hi all,
>>>We have noticed that image color in our videostream seems to
>>>have a lack of
>>>....accuracy to reality... i've seen other video streams that seem to
>>>reflect colors better and probably in a more real way. I was
>>>wondering where
>>>in the chain we can fix that. We are using a provisional Sony EVI D30
>>>camera, pinnacle pctv pro capture cards (i've tried as well
>>>with osprey 500,
>>>osprey 100 and hauppauge wintv go). Our display grahpics card
>>>is a nvidia
>>>quadro nvs and, finally, our display right now is composed of
>>>a brand new
>>>fujitsu TFT and a plasma TV.
>>>The codecs we are using are h261 (i think h263 cant be used
>>>with AG2.1.2 so
>>>far, is there any date about when will it be available?).
>>>Can anyone give us a piece of advice where we can improve our
>>>video quality?
>>>Kind regards and thank you in advance.
>>>Natalia.
>>>Natalia Costas Lago
>>>email: natalia at cesga.es
>>>Centro de Supercomputacion de Galicia (CESGA)
>>>Avenida de Vigo, s/n Campus Sur
>>>15705 Santiago de Compostela - SPAIN
>>>Tel:   +34  981 56 98 10
>>>Fax:  +34  981 59 46 16
>>>http://www.cesga.es/
> Natalia Costas Lago
> mailto: natalia at cesga.es
