[AG-TECH] Struggling with starting of producer service and encapsulated executable
Michael Braitmaier
braitmaier at hlrs.de
Thu May 6 07:13:20 CDT 2004
In fact we aim for integrating VR-collaboration into AccessGrid. At the
moment I am evaluating the different methods for integration. We already
did a small shared application coupling the UI part of the VR-controll
software with AccessGrid. Adiditionally I am working on a method of
allowing our render software to have a connection to access grid. As I
said this just experimental at the moment. But I think it might be a
good idea to consider our VR-rendering software as a kind of a
capability of a node, or in more detail have some kind of daemon or
server which provides a interface to the VR environment for other access
grid participants. This server would then also only be started if you
enter a venue or leave it, providing a continues stream of 3D data.
Initially I first want to check out the complexity of integration of our
application as a service before I decide on one way of implementation.
Therefore I wrote a small client server app just sending information
using sockets. I now want to incorporate this app into a producer
service python script so there is alaways a server app running on the
node and of course get a client instance of the app running when
entering a venu on the server.
But as described I still struggle with invoking my server app.
Furthermore I don' t know at which point to integrate the client side
application call.
Thanks
Michael
Ivan R. Judson wrote:
>Hi Michael,
>I'm sorry I haven't replied to your email yet, can you tell me what the
>application you are trying to incorporate does? It might be better
>integrated as a shared application rather than a node service, the
>difference being that shared applications are what users interact with, like
>a shared editor or shared rasmol application, whereas a node service is
>providing some underlying capability, like shared video or shared audio.
>Once configured the users doesn't start and stop the node services
>typically, there are automatically started and stopped when they enter a
>venue.
>I hope that helps a bit, please let me know what I can do to help.
>--Ivan
>>-----Original Message-----
>>From: owner-ag-tech at mcs.anl.gov
>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Braitmaier
>>Sent: Thursday, May 06, 2004 5:09 AM
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] Struggling with starting of producer
>>Currently I am trying to incorporate a simple executeable
>>into my VideoProducerService-derived own ProducerService.,
>>but I can't figure out some aspects of how the producer service works.
>>Especially I am stuck with the start method of the service.
>>As far as I understand it, for example the Videoproducer
>>service does nothing more than calling vis with appropriate
>>parameters passed in the options array. Therefore I wanted to
>>replace vic by my own executeable and accordingly change the
>>options passed to the called AGService._Start method. But
>>when I remove the options
>>self.streamDescription.location.host and
>>self.streamDescription.location.port my producer service
>>can't be added to my service manager because the service
>>manager reports that the service is unreachable. I thought
>>these values are only needed for vic to be able to broadcast
>>its video stream and receive video streams, so I should be
>>able to pass my own server information format at this point
>>which is understandable by my executeable. So what do I have
>>to pay attention to when replacing vic with my own
>>executeable concerning the start method of the producer
>>service, to avoid my service being unreachable ?
>>Any help would be greatly appreciated.
>>Michael
>>Michael Braitmaier
>>HLRS
>>University of Stuttgart
>>Germany
Michael Braitmaier
HLRS
Germany
