[AG-TECH] Quality of video in vic from Videum boards
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Tue May  4 03:50:11 CDT 2004
Many thanks for the tweak to get rid of the grey borders - Matt
or I will give it a whirl.
Bit puzzled by your comment about S-Video (aka Y-C) signal being
expected through a BNC connector: Y-C refers to the two components
(Y (luminance) and C (chrominance)) and so requires four pins
(three at a pinch, but I've never seen the grounds being shared).
Composite signals are normally bandwidth limited so that horizontal
resolution is limited to 250 lines or so; Y-C signals typically
produce 400 lines resolution [note for those not familiar with this:
this refers to what can be resolved along a horizontal scan line,
and is unrelated to the sampling (768 x 576, 640x480, 320x240 or
whatever) of the whole frame].  Personally I've never had the time
to set up a side-by-side comparison of the results of using
composite versus Y-C as the source of a video conference feed,
but both signals have so much more bandwidth than VC that I have
used whichever is more convenient, plug-and-socketwise, in VC
situations.
In the studio, of course, things are different and I use digital
for first preference, then component, then Y-C and composite as a
last choice, but then there's nothing scrunching the signal down
to less than a Mbit/sec in the signal chain!
Thanks again
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Randy Groves
> Sent: 30 April 2004 17:43
> To: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Quality of video in vic from Videum boards
> I may have found an answer to my quality issue.  I was under
> the impression
> (obviously in error) that the BNC connectors on the 4400 were
> generating
> S-Video - NOT! - they are composite outputs (I should have
> read the card
> specs more closely - my bad).  When I connect the Canon
> cameras over a
> composite connection they look quite nice.  I had a single conductor
> conversion cable to S-Video in the mix, and I was connecting
> the cameras
> via their S-Video connection, rather than the composite.
> As far as the grey border goes, here's an example of registry
> settings for
> HKEY_CURRENT_USER that will set the size to CIF (and also set
> the sources
> for the four vic streams).  You sould apply this AFTER you've
> started up
> the Venue Client and added the VideoConsumer streams for the 4
> connections.  You can just use parts of this if you wish.
> Obviously, you
> should be comfortable tweaking the registry.
> Windows Registry Editor Version 5.00
> [HKEY_CURRENT_USER\Software\Winnov\Videum\vic.exe0]
> "Width"=dword:00000160
> "Height"=dword:00000120
> "Compression"=dword:00000002
> "Source"=dword:00000000
> [HKEY_CURRENT_USER\Software\Winnov\Videum\vic.exe1]
> "Source"=dword:00000001
> [HKEY_CURRENT_USER\Software\Winnov\Videum\vic.exe2]
> "Source"=dword:00000002
> [HKEY_CURRENT_USER\Software\Winnov\Videum\vic.exe3]
> "Source"=dword:00000003
> Hope this helps.
> -randy
> At 08:04 AM 4/30/2004, Osland, CD (Chris) wrote:
> >We're running a Winnov 4400 with two cameras (and have tested with
> >4) under Windows XP and are getting good reports of our video
> >quality from remote sites.  I haven't looked for a way of getting
> >rid of the grey (gray!) surrounds yet, though.
> >Cheers
> >Chris
> >Chris Osland
> Office tel: +44
> >(0) 1235 446565
> >1235 446459
> Grid room tel: +44
> >(0) 1235 445666
>        Fax: +44
> >(0) 1235 445597
> use of the
> on it or show
> >it to anyone else,
> > > Sent: 06 April 2004 23:06
> > > Subject: [AG-TECH] Quality of video in vic from Videum boards
> > > I have to say that I'm not real impressed with the quality of
> > > the video
> > > that I see in the vic that is captured from a Winnov 1000 VO.
> > >  I also seem
> > > to remember thinking the same thing when I first saw the
> > > output in the vic
> > > that came from a Winnov 4400.  I just installed one in a
> > > machine that also
> > > has two Osprey 100 cards, and the difference is quite
> > > apparent.   The video
> > > in the vics from the Ospreys is clean and not pixelated at
> > > all.  The video
> > > from the vic that is coming from the Videum is quite pixelated.
> > > Is this just a basic problem?  Or is there a configuration
> > > that I'm not
> > > getting right?  Am I correct in thinking that the video
> > > output format from
> > > the card is significant to vic?  And if so, what is the
> > > optimum setting for
> > > this?  I've played with all that the Videum exposes (with
> > > VidCap32), but it
> > > doesn't seem to make much difference.  Leave aside the
> fact that the
> > > configuration tools for the Videum cards don't seem to have
> > > the same set of
> > > option tweaking capability that VidCap32 has, for instance.
> > > And since
> > > there doesn't seem to be a way to modify these, you are left
> > > with making
> > > registry hacks.
> > > I thought that Winnov was supposed to have superior Windows
> > > drivers, but so
> > > far I'm not that impressed.
> > > -randy
