[AG-TECH] Multi-channel video capture
A Quay
andy at digitalworlds.ufl.edu
Tue Mar 30 15:26:02 CST 2004
Did anybody every resolve this topic for the perfect quad-input video
capture card? I am about to build another three CPU ag node and would
really like to use a card such as the winnov videum 4400 quad input
video card or Ituner Spectra 8 video capture card due to my lack of PCI
slots.
I really need a card that performs seamlessly with AG 2.x and ideally
would like one that still works with AG 1.x.
Any suggestions would be great.
-andy
> -----Original Message-----
> From: "Osland, CD (Chris) " <C.D.Osland at rl.ac.uk>
> To: AG Tech <ag-tech at mcs.anl.gov>
> Date: Thu, 4 Mar 2004 13:56:52 -0000
> Subject: [AG-TECH] Multi-channel video capture
> My quest for efficient video capture of multiple channels via a
> single card continues.
> I was originally looking at the iTuner Spectra card (with 4
> channels) but have found that the UK supplier has given up
> 'because of problems with support'. Many thanks for those
> who replied, especially Bob Riddle; from him I understand
> that use of the Spectra card increases the amount of
> hand-knitting that has to be done whne switching venues.
> My next candidate is the Winnov Videum 4400 VO (or non-VO if
> I reckon I can use the audio interfaces to save on a sound
> card). Can the list tell me whether this would suffer in the
> same way (having to do extra work whenever you change venue)?
> I really want to increase automation, not add extra operator tasks.
> Many thanks in advance for any views.
> Cheers
> Chris Osland
> ____________________________________________________________________
> Chris Osland
> Office tel: +44
> (0) 1235 446565
> Digital Media and Access Grid
> Medialab tel: +44 (0)
> 1235 446459
> BIT Department Access
> Grid room tel: +44
> (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk
> Fax: +44
> (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the
> use of the
> intended recipient only.
> If you are not the intended recipient do not take any action
> on it or show
> it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > From: Bob Riddle [mailto:bdr at internet2.edu]
> > Sent: 12 February 2004 17:45
> > To: Osland, CD (Chris)
> > Cc: AG Tech
> > Subject: Re: [AG-TECH] hauppauge video problems
> > yes - but as Mike said, every time I switch venues and vic(s)
> > restart, I
> > get the little window (for each instance of vic) that asks me
> > to choose
> > my video source. That doesn't annoy me, so I'm a happy
> > Spectra8 card
> > user (and I opened up a couple more PCI slots!)
> > Osland, CD (Chris) wrote:
> > >Just to check, Bob...
> > >You say you're using the Spectra8 card - do I assume that you're
> > >using it successfully!? Under XP? If so, that's the way I'm
> > >going to go as well.
> > >Cheers
> > >Chris
> > >Chris Osland
> > Office tel: +44
> > >(0) 1235 446565
> > >1235 446459
> > Grid room tel: +44
> > >(0) 1235 445666
> > Fax: +44
> > >(0) 1235 445597
> > use of the
> > on it or show
> > >it to anyone else,
> > >>Sent: 11 February 2004 16:19
> > >>To: Michael Miller
> > >>Cc: Ti Leggett; Harold Micheal Goldman; AG Tech
> > >>I actually use a Spectra8 card on our "loaner" AG - it has
> > four video
> > >>ports on it and works the way Michael describes. I've been
> > >>trying to do
> > >>the same thing with a 4-port Winnov card as well ... (you
> > know, there
> > >>are only so many PCI port in a one-box node!)
> > >>Michael Miller wrote:
> > >>>Just to add to what Ti said:
> > >>>My experience has been that, depending on the driver, you
> > >>can select
> > >>>the WDM device in the configuration of multiple
> > >>VideoProducers. When
> > >>>vic starts up, one of the WDM cameras is automatically
> > selected for
> > >>>the first VideoProducer. Then you are given a series of
> > dialogs to
> > >>>choose a camera for each remaining VideoProducer. Again,
> > >>whether you
> > >>>get to choose another camera will depend on how the driver
> > >>enumerates
> > >>>the cameras. The QuickCam Pro 4000 does show you multiple
> > cameras,
> > >>>but it gives them all the same name. So, it can be
> confusing when
> > >>>trying to choose a camera for the subsequent
> > >>VideoProducers. If you
> > >>>have two different cameras, the WDM drivers will assign names as
> > >>>appropriate and it's much easier to decide which camera to
> > >>choose. I
> > >>>have an iBot firewire camera and a QuickCam Pro 4000 so
> I can see
> > >>>which camera has become the default after the last
> > session. If you
> > >>>have two of the same camera and the driver doesn't assign each a
> > >>>unique name, that's when you run into trouble.
> > >>>HTH
> > >>>Michael Miller
> > >>>NCSA
> > >>>At 05:36 PM 2/10/2004, Ti Leggett wrote:
> > >>>>Actually the problem is this. Vic can only handle Video
> > >>for Windows (VfW
> > >>>>devices) which is an old driver style. vic can map the
> > >>newer WDM drivers
> > >>>>to a VfW device, but it can only do that for one device.
> > >>Basically, if
> > >>>>you have drivers that are VfW then all of them will be
> > >>seen and usable
> > >>>>in vic. If the drivers are WDM only, then vic will pick a
> > >>device and map
> > >>>>and that's it. Hauppage has stopped providing VfW drivers
> > for their
> > >>>>cards. Osprey, however, still provides VfW drivers for
> > their cards.
> > >>>>This driver issue is also why you can only have one web
> > >>cam hooked up
> > >>>>since, I'd say, all web cams provide only WDM drivers.
> > >>>>Make more sense?
> > >>>>On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
> > >>>>>for what it's worth - I've been down this road and gave
> > >>up - while
> > >>>>this
> > >>>>>is no problem on Linux, the driver for WinXP assumes
