[AG-TECH] Questions about globus configuration
NamGon Kim
ngkim at netmedia.kjist.ac.kr
Thu Mar 25 06:30:15 CST 2004
Hi, All.
I am installing AG Toolkit to my own PC.
But I have a problem about setting globus configuration.
After executing globus Setup Wizard, I can go through the check globus
configuration and certificate configuration.
But while doing check network, I cannot go further.
1. The program error message is
" The network query failed ".
2. And this is the error message from console...
setting flag 536872960
Could not find value for x509_cert_file
compare: what=x509_user_proxy val=C:\DOCUME~1\ngkim\LOCALS~1\Temp\proxy
orig=C:\DOCUME~1\ngkim\LOCALS~1\Temp\proxy
compare: what=x509_cert_dir val=C:\Program Files\Windows
Globus\certificates orig=C:\Program Files\Windows Globus\certificates
compare: what=x509_user_key val=C:\Documents and
Settings\ngkim\Application Data\globus\userkey.pem orig=C:\Documents and
compare: what=x509_user_cert val=C:\Documents and
Settings\ngkim\Application Data\globus\usercert.pem orig=C:\Documents
and Settings\ngkim\Application Data\globus\usercert.pem
network query raised exception
Traceback (most recent call last):
File "globus_init.pyw", line 759, in ThreadQueryFunc
self.interfaces = winnet.enumerate_interfaces()
File "C:\Program Files\Windows Globus\config\winnet.py", line 63, in
name = reverse_lookup(adapter['ip'], adapter['dns'])
File "C:\Program Files\Windows Globus\config\winnet.py", line 123, in
reverse_lookup
res = DNS.Base.DnsRequest(ip_addr, qtype = 'ptr', server =
server).req().answers
File "C:\Python22\Lib\site-packages\DNS\Base.py", line 173, in req
self.sendUDPRequest(server)
File "C:\Python22\Lib\site-packages\DNS\Base.py", line 193, in
sendUDPRequest
self.response=self.processUDPReply()
File "C:\Python22\Lib\site-packages\DNS\Base.py", line 89, in
processUDPReply
raise DNSError, 'Timeout'
DNSError: Timeout
Does anyone experice this kind of error? And know the solution for this
situation?
I will wait for your answer. Thanks.
Namgon Kim
Netmedia Lab, K-JIST, KOREA
http://netmedia.kjist.ac.kr <http://netmedia.kjist.ac.kr/>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040325/1c0407b6/attachment.htm>
