[AG-TECH] AG support of Polycomm
Jennifer Teig von Hoffman
jtvh at bu.edu
Mon Mar 22 13:23:54 CST 2004
Hi Jeff,
Sounds to me like a network issue, as there are usually some streams in
the test room. If you want to be sure, go to the AG Lobby (the default
venue in the AG2 client; if you don't see anybody there it's almost
certain that this is a network issue. Chances are good you don't have
multicast.
Long term advice: Talk to your networking folks about this and have them
get working multicast to you.
Short term advice: Try "use unicast" from the "preferences" menu in the
Venue Client (in venues where this is available). Your media tools
should re-start and you should probably see streams in the test room.
And give a holler to this list again if you need somebody to meet you in
a venue to confirm whether or not you're getting all the appropriate
media streams.
- Jennifer
Jeff Sale wrote:
> Gurcharan,
> Thanks very much. We appear to have our system up and running, but I'm
> not sure how best to test it. I located a "Test Room" in the Virtual
> Venue but there were no active video streams besides mine. Any
> suggestions would be greatly appreciated.
> Jeff
> At 11:47 PM 3/19/2004 -0500, Gurcharan S. Khanna wrote:
>> --- You wrote:
>> First, has anyone successfully used a Polycomm ViewStation in an
>> Access Grid
>> node? Second, has anyone successfully implemented an AG node with a
>> configuration similar to ours?
>> --- end of quote ---
>> hi,
>> we have been using a Polycom Viewstation as the second camera in our
>> AG node.
>> we simply take the S-Video out of the Polycom and go into the Osprey
>> Card. note
>> that one of the s-vid outs on the polycom is the normal polycom out,
>> with the
>> on screen menuing system, the remote video, etc. the other s-vid out
>> is simply
>> the pure local video only. it shouldn't matter much what's providing
>> the s-vid
>> into the node, whether it's a polycom, or a sony or canon ptz cam,
>> which we
>> also use.
>> -gurcharan
>> Gurcharan S. Khanna
>> Associate Director
>> Research Computing
>> Dartmouth College
>> tele: 603-646-1644
>> http://research.dartmouth.edu
>> http://www.dartmouth.edu/~gkhanna
