[AG-TECH] Latest Tech Thoughts: document for discussion NOW
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Tue Mar 2 10:22:13 CST 2004
Just a few technical questions. I haven't seen the background
to this (the style of the document implies quite a bit of previous
work) so please disregard if things have already been discussed
before.
RCA connectors being used for video: these are second only to
S-Video connectors in their unreliability (OK, SCART connectors
are pretty bad too). For anything like this I would have thought
that reliability was key, so a locking (BNC) connector would be
vastly better.
Cellphones (= mobile phones): I work part-time in the Emergency
Department (= ER) in a large UK hospital (John Radcliffe in Oxford)
and anyone with a mobile phone switched on is given one chance and
about 15 seconds to turn it off anywhere inside the the hospital,
technically even in the restaurant. This applies to everyone -
surgeons, ambulance crews, police included. Maybe there's a culture
difference either side of the Atlantic, but the only things tolerated
over here are bleeps, which receive but do not transmit, and are
therefore not any sort of danger to ECG readings and other monitor
and control equipment. Maybe it's because of the different band
that the USA uses compared with the rest of the world.
Apologies if I have misunderstood.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Jonathan Silverstein [mailto:jcs at uchicago.edu]
> Sent: 02 March 2004 15:03
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Latest Tech Thoughts: document for discussion NOW
> LATEST THINKING ON O.R. SCENARIOS FROM TECHNICAL REQUIREMENTS
> VIEWPOINT
> The operating room hardware is constructed from the following
> elements,
> with specific items selected to meet the needs of each of the
> demonstration scenarios (note that wireless is advantageous for
> decreasing the complexity of the environment but not required):
> Existing video generating devices in O.R. (RCA
> video out and
> other options): laparoscope, overhead camera, room view
> Existing video generating devices in O.R.: DaVinci
> surgical
> system (several output options including two video streams
> left-eye,
> right-eye) surgical assistant today looks at only one mono-view on
> monitor over table while operating surgeon is at separate
> console with
> stereo viewing device and controls.
> Existing audio generating devices in O.R.: lapel
> microphone
> for surgeon
> Existing video display monitor (one) in O.R. (I think
> theyre RCA into a VCR)
> Head-mounted or hand-held displays for two users with
> head-tracking (each has to have their own view-point, but looking at
> the same content) for volume visualization
> Control system for head-mounted or hand-held displays
> (remote and/or local)
> Ambient audio play back (speakers) in the room
> Lapel microphone for assistant patched in
> Large format video display
> Control system for large format video display
> Compact AG node incorporating as many elements above as
> possible
> Notes: The communication points with the O.R. and the radiology
> workstation will consist of Fixed Standard AG nodes, Stereo
> enhanced AG
> nodes, compute/visualization servers, and hand-held nodes selected
> depending on scenarios. These are each under separate development
> within the ABC Testbed project and/or under base AG Team funding so
> will not be addressed here at this time (the whole AG Project is
> essentially assumed!). Only specific addition in regard to above is
> this: for the handheld wireless solution to be used in Hospitals,
> Hospitals are likely to have the following infrastructure in place in
> time for us: Tablet PC device or similar wireless laptop running XP
> with Hospitals information system running on it native OR through
> citrix this is significant in that if we create a dual boot
> device or
> use Windows or use small Mac running Citrix to create a
> portable node,
> we CAN issue the residents a single prototype machine on which they
> will be able to do all their usual work plus the ABC Testbed scenario!
> LATEST THINKING ON ER SCENARIOS FROM TECHNICAL REQUIREMENTS VIEWPOINT
> The field hardware is constructed from the following elements, with
> demonstration
> scenarios:
> compact, portable, battery-powered wireless high-resolution video
> camera.
> fixed location, wire-connected remote controlled
> camera (perhaps two one mounted IN ambulance for view of transport,
> one mounted ON ambulance for view of scene perhaps one with
> Velcro)
> prototype General Devices Rosetta signal processing device with
> multiple data inputs capable of interfacing with various camera types
> and multiple output interfaces capable of mating with various radios,
> cellphones, and satellite phones. (Depending on engineering, this may
> be an AG node as well or just an extension of the fixed AG node at
> hospital)
> conventional cellphone.
> next generation (high data-rate) cellphone.
> conventional EMS field radio.
> next generation (high data-rate) data-capable radio.
> satellite phone.
> The hospital hardware is constructed from the following
> elements, with
> specific items selected to meet the needs of each of the specific
> demonstration scenarios:
> CAREpoint EMS Workstation to: present video images; manage (decode,
> archive, re-transmit, etc.) those images; interface with various
> communications means; serve as an AG node.
> conventional telephone line for cellphone and satellite phone
> communications.
> conventional EMS field radio receiver.
> next generation (high data-rate) radio receiver.
