[AG-TECH] Would anyone be willing to install these certs?
    Matthew Martinez
    matthew at biochem.uthscsa.edu
    Thu Jun 24 10:07:35 CDT 2004
> okay, that all sounds correct. If you send me your client logfile I might
> be able to see what's going on.
> --bob
> At 09:51 AM 6/24/2004, Matthew Martinez wrote:
>> > Yes, it should. Did you install the clinet cert with an import so that
>> it
>> > picked up the private key?
>> > At 09:40 AM 6/24/2004, Matthew Martinez wrote:
>> >> >>so, does this mean my certs are supposed to work, assuming i
>> install
>> >> them
>> >> >>correctly?
>> >> > They are properly formed; have you been able to use them to connect
>> >> your
>> >> > client to your server?
>> >> > --bob
>> >>no, i haven't. I've installed the trusted CA on both the server and
>> the
>> >>client, then installed the client certificate on the client. it should
>> >>work right?
>>I'm not sure. i clicked on import in the import identity certificate, and
>>clicked on the certificate. then, it asked for a key, and the only key i
>>knew was the one i had created with openssl, so i imported that key, and
>>it asked for my password. I entered it, and it let me set that
>> certificate
>>as a default certificate, but wouldn't let me log into any venues.
ok, here it is.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040624/635ff8f5/attachment.txt>
