[AG-TECH] Shared app Gotchas
    Rob King
    r5king at ryerson.ca
    Wed Jun 23 11:12:12 CDT 2004
	Thank you very much!
	That cleared things right up!
	Since I seem to be running into all the problems I can, I've started
a page on the Access Grid Wiki devoted to shared app 'gotchas'.  I'll try to
put up situations that I encounter that have been hard to debug and might be
common there.  It would be great if any other shared app developers out
there could put up some of their experiences too
	The page is at:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/SharedAppGo
tchas?action=show
	Hopefully we can grow this, and make life easier for those who come
after us.
	Cheers,
	Rob King
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Susanne Lefvert
Sent: June 22, 2004 5:54 PM
To: Rob King
Cc: ag-tech at mcs.anl.gov
Subject: ***SPAM*** Re: [AG-TECH] Shared app callback problem
Rob,
You seem to have a newer version of wxPython installed so I have not
actually tried running the code. However, when calling ui components
outside of the main ui thread (as you do from your ag event callback) you
should use wxPostEvent or wxCallAfter to make sure things are working
properly. You can find a good example of wxPostEvent here:
http://wiki.wxpython.org/index.cgi/LongRunningTasks. I have been
using wxCallAfter so examples of that are in existing shared apps.
Susanne
On Tue, 22 Jun 2004, Rob King wrote:
> 	Thanks again Susanne,
> 	After looking at the shared question tool code it made much more
> sense.  I finally got the console apps up and running and it has been a
> great help in debugging so far.
> 	 I've finally narrowed down the problem I've been having.  It would
> seem as though there is some problem with creating an instance of a
wxPython
> widget from within a shared app event call-back.  Even when using the same
> code for object creation, when instantiated from within a call-back the
> object locks up (even though traces in the __init__ seem to indicate it
> initializes fine).  I think it might be some sort of funky threading
> conflict between AGTK, and wxPython...
> 	Below I have included the code of a really small shared app that
> exhibits this behaviour.  To try it, simply paste the code into a .py
file,
> replace appUrl with an application session (though I'll keep the current
one
> up, so it *should* work as is), and run it from the command line.
> 	If running one instance, pressing the new note button should pop up
> a yellow tooltip that can be moved with the mouse.  To see the problem run
> two instances (on the same or different computers...shouldn't matter).
> Pressing the new note button will work as it should in the app where the
> button was pressed.  A yellow tooltip will also pop up on the receiving
end,
> but the widget will lock up, so when mousing over you get an hour glass,
and
> you cannot move the tooltip anymore.
> 	Hopefully someone will be able to help me figure this one out, as
> this same problem has been plaguing me over the past month+.
> 	Thanks in advance!
> 	-rob king
> ###########################Start code##################################
> from wxPython.wx import *
> import AccessGrid.SharedAppClient
> from AccessGrid.Toolkit import CmdlineApplication
> class StickyBoard(wxApp):
>     def __init__( self, appUrl, debugMode = 1, logFile = None):
>         self.appURL = appUrl
>         # Create shared application client
>         self.sharedAppClient =
> AccessGrid.SharedAppClient.SharedAppClient("StickyBoard")
>         self.log = self.sharedAppClient.InitLogging(debugMode, logFile)
>         self.app = CmdlineApplication.instance()
>         self.app.Initialize("Sticky Board")
>         # Connect to shared application service.
>         self.sharedAppClient.Join(appUrl)
>         wxApp.__init__(self, False)
>     def OnInit(self):
>         self.Control = StickyBoardControl(self)
>         self.SetTopWindow(self.Control)
>         self.Control.Show(1)
>         self.sharedAppClient.RegisterEventCallback("note",
> self.Control.noteCB )
>         return 1
> class StickyBoardControl(wxFrame):
>     def __init__(self, parent):
>         kwds =
{"style":wxCAPTION|wxMINIMIZE_BOX|wxCLOSE_BOX|wxSYSTEM_MENU|wxRESIZE_BORDER,
> "size":(120, 120), "pos":(0,0)}
>         wxFrame.__init__(self, *(None, -1, ""), **kwds)
>         self.parent = parent
>         self.notes = []
>         self.button = wxButton(self, -1, "New Note")
>         self.Bind(EVT_BUTTON, self.newSticky, self.button)
>         box = wxBoxSizer(wxVERTICAL)
>         box.Add((0, 0))
>         box.Add(self.button, 0, wxALIGN_CENTER|wxALL, 15)
>         self.SetAutoLayout(True)
>         self.SetSizer(box)
>     def noteCB(self, event):
>         senderId = event.data
>         if senderId == self.parent.sharedAppClient.GetPublicId():
>             self.parent.log.debug("Ignoring edit message from myself ")
>         else:
>             self.parent.log.debug( "adding note" )
>             self.note = Note(self, wxSIMPLE_BORDER)
>     def newSticky(self, event=None):
>         publicID = self.parent.sharedAppClient.GetPublicId()
>         self.parent.sharedAppClient.SendEvent("note", (publicID))
> class Note(wxPopupWindow):
>     def __init__(self, parent, style, text = None, pos = None):
>         wxPopupWindow.__init__(self, parent, style)
>         self.SetBackgroundColour("GOLDENROD")
>         self.SetSize((50,50))
>         self.Bind(EVT_LEFT_DOWN, self.OnMouseLeftDown)
>         self.Bind(EVT_MOTION, self.OnMouseMotion)
>         self.Bind(EVT_LEFT_UP, self.OnMouseLeftUp)
>         self.Show(1)
>     def OnMouseLeftDown(self, evt):
>         self.ldPos =
evt.GetEventObject().ClientToScreen(evt.GetPosition())
>         self.wPos = self.ClientToScreen((0,0))
>         self.CaptureMouse()
>     def OnMouseMotion(self, evt):
>         if evt.Dragging() and evt.LeftIsDown():
>             dPos = evt.GetEventObject().ClientToScreen(evt.GetPosition())
>             nPos = (self.wPos.x + (dPos.x - self.ldPos.x),
>                     self.wPos.y + (dPos.y - self.ldPos.y))
>             self.Move(nPos)
>     def OnMouseLeftUp(self, evt):
>         self.ReleaseMouse()
> if __name__ == "__main__":
>     # Url from app properties dialog in venue client.  Change these!
>     appUrl = 'https://vv2.mcs.anl.gov:9000/119'
>     debugMode = 1
>     stickyBoard = StickyBoard(appUrl, debugMode, None)
>     stickyBoard.MainLoop()
> #############################end code####################################
> From: Susanne Lefvert [mailto:lefvert at mcs.anl.gov]
> Sent: June 21, 2004 3:12 PM
> To: Rob King
> Subject: RE: [AG-TECH] Errors silenced?
> Hello Rob,
> I have tried to answer your questions below.
> Regards,
> Susanne
> On Mon, 21 Jun 2004, Rob King wrote:
> > 	Hmmm... I think I must be missing something here...
> > 	I tried putting this in a file (test.py):
> > appUrl = 'https://vv2.mcs.anl.gov:9000/208'
> > And ran it, but nothing happened.  It just ran through and ended.
> > I also tried with app.Initialize("StickyBoard.py"), and that did nothing
> as
> > well.
> > So a few questions:
> > Should <appName> be the name registered in the venue client, or the
> > filename?
> You can set <appName> to whatever you want, I used "SharedQuestionTool".
> > Should the code above be a standalone app run from a command prompt, or
> > should the code be incorporated into my shared app code somehow?
> > I looked in the toolkit.py sourcecode, and I can't find where it
actually
> > runs the app, or takes in the appURL... am I looking at this wrong?
> You can see an example of how I am using the code in
> /AccessGrid/sharedapps/SharedQuestionTool/SharedQuestionTool.py
> > I also took a look at the AccessGrid/tools/VenueApp.py file, and from
what
> I
> > could interpret, it seems to create an application session on the server
> but
> > doesn't run the application locally.  Again I may be mistaken though.
> That's correct. You can use that code if you want to get access to an
> application url without having to open the application session properties
> dialog in the Venue Client.
> > 	Hopefully you can help me with this!
> > 	Thanks a lot,
> > 	Rob king
> Behalf
> > Of Susanne Lefvert
> > Sent: June 17, 2004 4:06 PM
> > To: Rob King
> > Subject: Re: [AG-TECH] Errors silenced?
> > Hello Rob,
> > I am glad to hear that you are working on a shared application for the
AG
> > and would like to help you with your logging issue.  Apparently, log
files
> > for shared apps are not created properly and we are working to get that
> > fixed.  In the mean time, you can use following code to test your app
> > outside of the venue client:
> > app.Initialize("<appName>")
> > # Url from app properties dialog in venue client (the 'Location
> > # URL' field in the dialog that shows up when you right click the
> > # application session you want to use and select 'Properties').
> > appUrl = 'https://<host>:<port>/....'
> > This will print errors to the console and create a log <appName>.log
file
> > where you are running your application.  Also,
> > AccessGrid/tools/VenueApp.py in cvs shows you how to create an
> > application session in the venue without using the venue client.
> > Hope this helps,
> > Susanne
> > On Thu, 17 Jun 2004, Rob King wrote:
> > >             Hello Everyone,
> > >             I am working on developing a shared application right now,
> but
> > > have been having some problems.  I could probably figure them out, but
> it
> > > seems as though the errors are being suppressed somewhere.  It's
> happened
> > in
> > > a couple of places so far, and problems become difficult to debug.  I
> have
> > > debug logging mode on, but when it gets to an error, it doesn't log
it,
> it
> > > just stops.  Is there some way to coax the error messages into a log
or
> > even
> > > the debug console?  My current method of putting a debug log statement
> > every
> > > couple lines of code has only met with limited success ;)
> > >             Hope someone can help!
> > >             -rob king
> > __________ NOD32 1.772 (20040524) Information __________
> > This message was checked by NOD32 Antivirus System.
> > http://www.nod32.com
