[AG-TECH] BasicImage
    Benedikt Bjarni Bogason
    benedib at hi.is
    Tue Jun 22 11:44:34 CDT 2004
I've been trying out the shared browser, and presentation which have
worked well as far as I could tell (being the only node in the system made
the test a little pointless, but nonetheless..).
So now I wanted to try and get the image viewer app, called Basic Image,
and I followed the very thorough instructions by Dave Semeraro found on
this page:
http://cherokee.ncsa.uiuc.edu/~semeraro/Stupid_AG_Tricks/default.htm
I registered the application using agpm.py and I was able to select Add
Application -> Basic Image from the Venue menu, but when I tried to open
the Basic Image which was listed in Applications, nothing happened.
Can anyone explain this to me, I thought I had followed the instructions
to the letter.
Here are the log files for the VenueServer and VenueClient if that is of
any use..
------------------------VenueClient--------------------------
06/22/04 17:29:59 1908 Toolkit     config.py:205 DEBUG System hostname of
b48133.dhcp.futures.bt.co.uk is valid
06/22/04 17:29:59 1908 CertificateManager     certificatemanager.py:261
DEBUG Opened repository C:\Documents and Settings\nekovem\Application
Data\AccessGrid\Config\certRepo
06/22/04 17:30:00 1908 CertificateManager     certificatemanager.py:717
DEBUG Configuring standard environment
06/22/04 17:30:00 1908 CertificateManager     certificatemanager.py:783
DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/b48133.dhcp.futures.bt.co.uk
06/22/04 17:30:00 1908 CertificateManager     certificatemanager.py:1023
DEBUG Initializing environment with unencrypted cert /O=Access
06/22/04 17:30:00 1908 VenueClient     venueclient.py:293 DEBUG
__StartWebService: venueclient:
https://b48133.dhcp.futures.bt.co.uk:11000/VenueClient
06/22/04 17:30:00 1908 ServiceManager     agservicemanager.py:70 INFO
Using services dir: C:\Documents and Settings\nekovem\Application
Data\AccessGrid\local_services
06/22/04 17:30:00 1908 ServiceManager     agservicemanager.py:453 INFO
__DiscoverResources
06/22/04 17:30:00 1908 Toolkit     config.py:1013 ERROR Exception getting
video devices
Traceback (most recent call last):
  File
"C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py",
line 995, in GetResources
    videoKey = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, key)
WindowsError: [Errno 2] The system cannot find the file specified
06/22/04 17:30:00 1908 ServiceManager     agservicemanager.py:457 ERROR
Exception getting resources
  File "C:\Python23\Lib\site-packages\AccessGrid\AGServiceManager.py",
line 455, in __DiscoverResources
    self.resources = SystemConfig.instance().GetResources()
  File
06/22/04 17:30:00 1908 VenueClient     venueclient.py:302 DEBUG
__StartWebService: service manager:
https://b48133.dhcp.futures.bt.co.uk:11000/ServiceManager
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:667 INFO
NodeService.__ReadConfigFile
06/22/04 17:30:00 1908 Toolkit     toolkit.py:264 DEBUG Looking for:
Data\AccessGrid\Config\AGNodeService.cfg
06/22/04 17:30:00 1908 Toolkit     toolkit.py:269 DEBUG Looking for:
C:\Program Files\AGTk-2.2\Config\AGNodeService.cfg
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:675 DEBUG DEFAULT
NODE SERVICE CONFIG: C:\Program Files\AGTk-2.2\Config\AGNodeService.cfg
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:679 INFO  Reading
node service config file: C:\Program
06/22/04 17:30:00 1908 DataStore     datastore.py:1515 DEBUG Creating
thread 0
06/22/04 17:30:00 1908 DataStore     datastore.py:1520 DEBUG Starting
thread 0
06/22/04 17:30:00 1832 DataStore     datastore.py:1528 DEBUG Worker 0
starting
06/22/04 17:30:00 1908 DataStore     datastore.py:1522 DEBUG Waiting thread 0
06/22/04 17:30:00 1908 DataStore     datastore.py:1525 DEBUG Done creating
workers
06/22/04 17:30:00 1908 ServicePackageRepo
agservicepackagerepository.py:63 INFO  Started AGServicePackageRepository
Transfer Server
agservicepackagerepository.py:64 INFO   url =
https://b48133.dhcp.futures.bt.co.uk:52887/packages/
agservicepackagerepository.py:65 INFO   dir = C:\Program
Files\AGTk-2.2\NodeServices
06/22/04 17:30:00 1908 VenueClient     venueclient.py:308 DEBUG
__StartWebService: node service:
https://b48133.dhcp.futures.bt.co.uk:11000/NodeService
06/22/04 17:30:00 1908 VenueClient     venueclient.py:1522 DEBUG
SerNodeUrl: Set node service url:
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:360 INFO
NodeService.LoadDefaultConfig
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:364 INFO  Loading
default node configuration: defaultWindows
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:378 INFO
NodeService.LoadConfiguration
06/22/04 17:30:00 1908 NodeService     agnodeservice.py:393 INFO  Trying
to load node configuration from: C:\Documents and
Data\AccessGrid\Config\nodeConfig\defaultWindows
06/22/04 17:30:02 1156 ServiceManager     agservicemanager.py:388 INFO
AGServiceManager.RemoveServices
06/22/04 17:30:02 1156 ServiceManager     agservicemanager.py:106 INFO
AGServiceManager.AddService
06/22/04 17:30:02 1156 ServiceManager     agservicemanager.py:109 INFO
AddService: AudioService v 2.200000 u
https://b48133.dhcp.futures.bt.co.uk:52887/packages/AudioService.zip
06/22/04 17:30:02 1156 ServiceManager     agservicemanager.py:113 INFO
resourceToAssign: None
06/22/04 17:30:02 1156 ServiceManager     agservicemanager.py:151 INFO
Searching for local service package
06/22/04 17:30:03 1156 ServiceManager     agservicemanager.py:159 INFO
Found local service AudioService, v2
06/22/04 17:30:03 1156 ServiceManager     agservicemanager.py:241 INFO
Running Service; options: C:\Python23\python.exe [u'C:\\Documents and
Settings\\nekovem\\Application
Data\\AccessGrid\\local_services\\AudioService\\AudioService.py', 50786]
06/22/04 17:30:03 1156 ProcessManager     processmanager.py:62 DEBUG
Creating process: C:\Python23\python.exe "C:\Documents and
Data\AccessGrid\local_services\AudioService\AudioService.py" 50786
06/22/04 17:30:03 1156 ProcessManager     processmanager.py:75 DEBUG
Create process returns: (<PyHANDLE object at 0x02150C84>, <PyHANDLE object
at 0x02152ADC>, 1976, 1948)
06/22/04 17:30:03 1156 ServiceManager     agservicemanager.py:258 DEBUG
Waiting for service to start: AudioService
https://b48133.dhcp.futures.bt.co.uk:50786/Service
06/22/04 17:30:08 1156 ServiceManager     agservicemanager.py:265 INFO
Service AudioService successfully started
06/22/04 17:30:08 1156 ServiceManager     agservicemanager.py:299 DEBUG
Not setting service configuration; none given
06/22/04 17:30:08 1156 ServiceManager     agservicemanager.py:308 DEBUG
Not assigning resource; none given
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:106 INFO
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:109 INFO
AddService: VideoConsumerService v 2.200000 u
https://b48133.dhcp.futures.bt.co.uk:52887/packages/VideoConsumerService.zip
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:113 INFO
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:151 INFO
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:159 INFO
Found local service VideoConsumerService, v2
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:241 INFO
Data\\AccessGrid\\local_services\\VideoConsumerService\\VideoConsumerService.py',
60510]
06/22/04 17:30:09 1768 ProcessManager     processmanager.py:62 DEBUG
Data\AccessGrid\local_services\VideoConsumerService\VideoConsumerService.py"
60510
06/22/04 17:30:09 1768 ProcessManager     processmanager.py:75 DEBUG
Create process returns: (<PyHANDLE object at 0x0229EEC4>, <PyHANDLE object
at 0x021C2BD4>, 1292, 1156)
06/22/04 17:30:09 1768 ServiceManager     agservicemanager.py:258 DEBUG
Waiting for service to start: VideoConsumerService
https://b48133.dhcp.futures.bt.co.uk:60510/Service
06/22/04 17:30:14 1768 ServiceManager     agservicemanager.py:265 INFO
Service VideoConsumerService successfully started
06/22/04 17:30:14 1768 ServiceManager     agservicemanager.py:299 DEBUG
06/22/04 17:30:14 1768 ServiceManager     agservicemanager.py:308 DEBUG
06/22/04 17:30:15 1908 VenueClient     venueclient.py:190 DEBUG
__createPersonalDataStore: Creating personal datastore at C:\Documents and
Settings\nekovem\Application Data\AccessGrid\Config\personalDataStore
using prefix personalDataStore and port 0
06/22/04 17:30:15 1908 DataStore     datastore.py:1515 DEBUG Creating
thread 0
06/22/04 17:30:15 1908 DataStore     datastore.py:1520 DEBUG Starting
thread 0
06/22/04 17:30:15 716 DataStore     datastore.py:1528 DEBUG Worker 0 starting
06/22/04 17:30:15 1908 DataStore     datastore.py:1522 DEBUG Waiting thread 0
06/22/04 17:30:15 1908 DataStore     datastore.py:1525 DEBUG Done creating
workers
06/22/04 17:30:15 1908 DataStore     datastore.py:273 DEBUG Reading
persisted data from: C:\Documents and Settings\nekovem\Application
Data\AccessGrid\Config\personalDataStore\DataStore.dat
06/22/04 17:30:15 1908 DataStore     datastore.py:282 INFO
LoadPersistentVenues: Data has no description
06/22/04 17:30:15 1908 VenueClient     venueclient.py:215 DEBUG
__createPersonalDataStore: Load personal data from file
06/22/04 17:31:03 1908 VenueClient     venueclient.py:765 DEBUG
EnterVenue; url=https://b48133.dhcp.futures.bt.co.uk:8000/Venues/default
06/22/04 17:31:03 1400 NodeService     agnodeservice.py:626 INFO
NodeService.GetCapabilities
06/22/04 17:31:03 1400 NodeService     agnodeservice.py:242 INFO
NodeService.GetServices
06/22/04 17:31:04 288 ServiceManager     agservicemanager.py:400 INFO
AGServiceManager.GetServices
06/22/04 17:31:07 1908 VenueClient     venueclient.py:686 DEBUG
EnterVenue: Invoke venue enter
06/22/04 17:31:09 1908 EventClient     eventclient.py:166 DEBUG Have
callback handle _c0f53f01_p_callbackStruct
06/22/04 17:31:09 1908 TextConnection     textclient.py:145 DEBUG
TextConnection: register returns _103f4201_p_callbackStruct
06/22/04 17:31:09 1908 TextConnection     textclient.py:147 DEBUG
	host:b48133.dhcp.futures.bt.co.uk
	port:8004
	attr:<pyGlobus.io.TCPIOAttr instance at 0x024C5698>
06/22/04 17:31:09 1908 TextConnection     textclient.py:149 DEBUG
	socket:<pyGlobus.io.GSITCPSocket instance at 0x024C5760>
06/22/04 17:31:09 1908 TextConnection     textclient.py:164 DEBUG
TextConnection.Write: EVENT --- Input
06/22/04 17:31:09 1908 TextConnection     textclient.py:165 DEBUG
TextConnection.Write: Event:
	Type: Connect	Venue: 000000fd4cba42a60084009200700085409	Data:
000000fd4d324ca800840092007000851bb
06/22/04 17:31:09 1908 VenueClient     venueclient.py:752 DEBUG Setting
isInVenue flag.
06/22/04 17:31:09 1908 VenueClient     venueclient.py:1205 DEBUG
UpdateNodeService: Method UpdateNodeService called
06/22/04 17:31:11 1932 NodeService     agnodeservice.py:645 INFO
NodeService.SetIdentity
06/22/04 17:31:11 1932 NodeService     agnodeservice.py:242 INFO
06/22/04 17:31:12 1820 ServiceManager     agservicemanager.py:400 INFO
06/22/04 17:31:14 1908 VenueClient     venueclient.py:1252 DEBUG
UpdateStream: Setting stream 000000fd4d324cc6008400920070008530f to
multicast
06/22/04 17:31:15 1932 NodeService     agnodeservice.py:311 INFO
NodeService.SetStreams
06/22/04 17:31:15 1932 NodeService     agnodeservice.py:242 INFO
06/22/04 17:31:16 1820 ServiceManager     agservicemanager.py:400 INFO
06/22/04 17:31:16 1932 NodeService     agnodeservice.py:716 INFO
NodeService.__SendStreamsToService
06/22/04 17:31:17 1932 NodeService     agnodeservice.py:726 INFO  Sending
stream (type=audio) to service:
06/22/04 17:31:19 1932 NodeService     agnodeservice.py:716 INFO
06/22/04 17:31:20 1908 VenueClient     venueclient.py:810 DEBUG Updating
client profile cache.
06/22/04 17:31:20 1908 VenueClientUI     venueclientui.py:2053 DEBUG
bin.VenueClient::EnterVenue: Enter venue with url:
06/22/04 17:31:20 1908 VenueClientUI     venueclientui.py:2161 DEBUG
Entered venue
06/22/04 17:31:20 1908 VenueClientUI     venueclientui.py:2718 DEBUG
ContentListPanel.AddParticipant:: AddParticipant Benedikt Bjarni Bogason,
BBB (called from ('C:\\Python23\\Lib\\site-packages\\wxPython\\wx.py',
1712, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw)
06/22/04 17:31:38 1908 VenueClientUI     venueclientui.py:3268 INFO  Got
commands: (application/x-ag-basic-image) {'Open':
'C:\\Python23\\python.exe AGBasicImage.py %(appUrl)s %(venueUrl)s'}
06/22/04 17:31:39 1908 VenueClientController
venueclientcontroller.py:1252 INFO  StartCmd starting command:
C:\Python23\python.exe AGBasicImage.py
https://b48133.dhcp.futures.bt.co.uk:8000/Venues/000000fd4cba42a60084009200700085409/apps/000000fd4d2e708e00840092007000855cb
06/22/04 17:31:39 1908 ProcessManager     processmanager.py:62 DEBUG
Creating process: C:\Python23\python.exe AGBasicImage.py
06/22/04 17:31:39 1908 ProcessManager     processmanager.py:75 DEBUG
Create process returns: (<PyHANDLE object at 0x0229FD04>, <PyHANDLE object
at 0x024D43A4>, 740, 1768)
06/22/04 17:32:20 1908 VenueClientUI     venueclientui.py:1700 INFO
--------- END VenueClient
06/22/04 17:32:20 1908 VenueClient     venueclient.py:920 INFO  ExitVenue
06/22/04 17:32:20 1908 ProcessManager     processmanager.py:135 ERROR
couldn't shutdown process <PyHANDLE:1288>: (1444, 'PostThreadMessage',
'Invalid thread identifier.')
  File
"C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.py",
line 128, in TerminateProcess
    win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
06/22/04 17:32:20 1908 ProcessManager     processmanager.py:142 ERROR
couldn't terminate process <PyHANDLE:1288>: (5, 'TerminateProcess',
'Access is denied.')
  File
line 139, in TerminateProcess
    win32process.TerminateProcess(pid, 0)
error: (5, 'TerminateProcess', 'Access is denied.')
06/22/04 17:32:20 1908 VenueClient     venueclient.py:950 INFO  ExitVenue:
Stopping event client
06/22/04 17:32:20 1908 VenueClient     venueclient.py:954 DEBUG ExitVenue:
Send client exiting event
06/22/04 17:32:21 1848 EventClient     eventclient.py:183 DEBUG Got read
handle=_40fc3e01_p_globus_io_handle_t result=(-1, 32, 'an end-of-file was
reached')  n=0
06/22/04 17:32:21 1848 EventClient     eventclient.py:186 DEBUG
readCallback gets failure in result: -1 32
06/22/04 17:32:21 1908 VenueClient     venueclient.py:968 INFO  ExitVenue:
Stopping node services
06/22/04 17:32:22 1424 NodeService     agnodeservice.py:287 INFO
NodeService.StopServices
06/22/04 17:32:23 992 ServiceManager     agservicemanager.py:408 INFO
AGServiceManager.StopServices
06/22/04 17:32:24 288 EventClient     eventclient.py:279 ERROR Attempting
to send on a disconnected EventClient
06/22/04 17:32:24 288 VenueClient     venueclient.py:358 ERROR Heartbeat:
Heartbeat exception is caught.
  File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
356, in __Heartbeat
    self.privateId))
  File "C:\Python23\Lib\site-packages\AccessGrid\EventClient.py", line
280, in Send
    raise EventClientWriteDataException
06/22/04 17:32:24 288 VenueClient     venueclient.py:372 INFO  Try to
reconnect to venue
06/22/04 17:32:24 288 VenueClient     venueclient.py:883 INFO  ExitVenue:
Stopping heartbeats
06/22/04 17:32:24 288 VenueClient     venueclient.py:888 DEBUG ExitVenue:
Stop event client obj
06/22/04 17:32:24 288 EventClient     eventclient.py:301 DEBUG Cancel
pending callbacks
06/22/04 17:32:24 288 EventClient     eventclient.py:307 DEBUG Free
callback _c0f53f01_p_callbackStruct
06/22/04 17:32:24 288 EventClient     eventclient.py:313 DEBUG
EventClient.Stop: closing socket
06/22/04 17:32:24 288 EventClient     eventclient.py:321 DEBUG
EventClient.Stop: closing queue
06/22/04 17:32:24 288 VenueClient     venueclient.py:890 DEBUG ExitVenue:
Remove event client reference
06/22/04 17:32:24 288 VenueClient     venueclient.py:895 INFO  ExitVenue:
Stopping text client
06/22/04 17:32:24 288 VenueClient     venueclient.py:899 DEBUG ExitVenue:
Sending client disconnect event.
06/22/04 17:32:24 288 TextConnection     textclient.py:164 DEBUG
06/22/04 17:32:24 288 TextConnection     textclient.py:165 DEBUG
	Type: Disconnect	Venue: 000000fd4cba42a60084009200700085409	Data:
06/22/04 17:32:24 1096 TextConnection     textclient.py:207 DEBUG
TextConnection: Got read handle=_68a24101_p_globus_io_handle_t ret=(-1,
38, 'an I/O operation was cancelled')  n=0
06/22/04 17:32:24 1096 TextConnection     textclient.py:210 DEBUG
TextConnection: asynch read gets n=0, EOF
06/22/04 17:32:24 288 TextConnection     textclient.py:154 DEBUG
TextClient.Stop
06/22/04 17:32:24 288 VenueClient     venueclient.py:902 DEBUG ExitVenue:
Remove text client reference
06/22/04 17:32:24 288 VenueClient     venueclient.py:686 DEBUG EnterVenue:
Invoke venue enter
06/22/04 17:32:30 1424 NodeService     agnodeservice.py:311 INFO
06/22/04 17:32:30 1424 NodeService     agnodeservice.py:242 INFO
06/22/04 17:32:30 1528 ServiceManager     agservicemanager.py:400 INFO
06/22/04 17:32:31 288 EventClient     eventclient.py:166 DEBUG Have
callback handle _80ec4301_p_callbackStruct
06/22/04 17:32:31 1424 NodeService     agnodeservice.py:716 INFO
06/22/04 17:32:33 288 TextConnection     textclient.py:145 DEBUG
TextConnection: register returns _08614101_p_callbackStruct
06/22/04 17:32:33 288 TextConnection     textclient.py:147 DEBUG
	port:8004
	attr:<pyGlobus.io.TCPIOAttr instance at 0x02585198>
06/22/04 17:32:33 288 TextConnection     textclient.py:149 DEBUG
	socket:<pyGlobus.io.GSITCPSocket instance at 0x02585558>
06/22/04 17:32:33 288 TextConnection     textclient.py:164 DEBUG
06/22/04 17:32:33 288 TextConnection     textclient.py:165 DEBUG
000000fd4d33821f0084009200700085ff3
06/22/04 17:32:33 288 VenueClient     venueclient.py:752 DEBUG Setting
isInVenue flag.
06/22/04 17:32:33 288 VenueClientUI     venueclientui.py:2053 DEBUG
06/22/04 17:32:33 288 VenueClientUI     venueclientui.py:2161 DEBUG
Entered venue
06/22/04 17:32:33 1424 NodeService     agnodeservice.py:716 INFO
06/22/04 17:32:34 1908 VenueClient     venueclient.py:883 INFO  ExitVenue:
Stopping heartbeats
06/22/04 17:32:34 1908 VenueClient     venueclient.py:888 DEBUG ExitVenue:
06/22/04 17:32:34 1908 EventClient     eventclient.py:301 DEBUG Cancel
pending callbacks
06/22/04 17:32:34 1096 EventClient     eventclient.py:183 DEBUG Got read
handle=_50234801_p_globus_io_handle_t result=(-1, 49, 'an I/O operation
was cancelled')  n=0
06/22/04 17:32:34 1096 EventClient     eventclient.py:186 DEBUG
readCallback gets failure in result: -1 49
06/22/04 17:32:34 1908 EventClient     eventclient.py:307 DEBUG Free
callback _80ec4301_p_callbackStruct
06/22/04 17:32:34 1908 EventClient     eventclient.py:313 DEBUG
06/22/04 17:32:34 1908 EventClient     eventclient.py:321 DEBUG
06/22/04 17:32:34 1908 VenueClient     venueclient.py:890 DEBUG ExitVenue:
06/22/04 17:32:34 1908 VenueClient     venueclient.py:895 INFO  ExitVenue:
06/22/04 17:32:34 1908 VenueClient     venueclient.py:899 DEBUG ExitVenue:
06/22/04 17:32:34 1908 TextConnection     textclient.py:164 DEBUG
06/22/04 17:32:34 1908 TextConnection     textclient.py:165 DEBUG
06/22/04 17:32:34 992 TextConnection     textclient.py:207 DEBUG
TextConnection: Got read handle=_701a3f01_p_globus_io_handle_t ret=(-1,
56, 'an I/O operation was cancelled')  n=0
06/22/04 17:32:34 992 TextConnection     textclient.py:210 DEBUG
06/22/04 17:32:34 1908 TextConnection     textclient.py:154 DEBUG
TextClient.Stop
06/22/04 17:32:34 1908 VenueClient     venueclient.py:902 DEBUG ExitVenue:
06/22/04 17:32:34 1908 NodeService     agnodeservice.py:120 INFO
NodeService.Stop
06/22/04 17:32:34 1908 ServiceManager     agservicemanager.py:79 INFO
AGServiceManager.Shutdown
06/22/04 17:32:34 716 DataStore     datastore.py:1533 DEBUG Worker 0 gets
cmd quit
06/22/04 17:32:34 1236 DataStore     datastore.py:1604 INFO
GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
likely shutting down.
06/22/04 17:32:34 1832 DataStore     datastore.py:1533 DEBUG Worker 0 gets
cmd quit
06/22/04 17:32:34 2028 DataStore     datastore.py:1604 INFO
06/22/04 17:32:34 716 DataStore     datastore.py:1546 DEBUG Worker 0 exiting
06/22/04 17:32:34 1832 DataStore     datastore.py:1546 DEBUG Worker 0 exiting
06/22/04 17:32:34 1908 ServiceManager     agservicemanager.py:80 INFO
Remove services
06/22/04 17:32:34 1908 ServiceManager     agservicemanager.py:388 INFO
06/22/04 17:32:34 1908 ServiceManager     agservicemanager.py:329 INFO
06/22/04 17:32:35 1908 ProcessManager     processmanager.py:133 WARNING
Couldn't terminate process <PyHANDLE:24> cleanly (258)
06/22/04 17:32:35 1908 ServiceManager     agservicemanager.py:329 INFO
06/22/04 17:32:37 1908 ProcessManager     processmanager.py:133 WARNING
Couldn't terminate process <PyHANDLE:1272> cleanly (258)
06/22/04 17:32:37 1908 ServiceManager     agservicemanager.py:82 INFO
Stop network interface
------------------------VenueServer--------------------------
06/22/04 17:29:28 484 Toolkit     toolkit.py:547 INFO  Service init: have
profile None
06/22/04 17:29:28 484 Toolkit     config.py:205 DEBUG System hostname of
06/22/04 17:29:28 484 CertificateManager     certificatemanager.py:261
06/22/04 17:29:28 484 Toolkit     toolkit.py:573 INFO  Initialized cert mgmt.
06/22/04 17:29:28 484 Toolkit     toolkit.py:588 INFO  Loaded profile and
configured with it.
06/22/04 17:29:29 484 CertificateManager     certificatemanager.py:717
06/22/04 17:29:29 484 CertificateManager     certificatemanager.py:783
06/22/04 17:29:29 484 CertificateManager     certificatemanager.py:1023
06/22/04 17:29:29 484 Toolkit     toolkit.py:592 INFO  Initialized Globus.
06/22/04 17:29:29 484 DataStore     datastore.py:1515 DEBUG Creating thread 0
06/22/04 17:29:29 484 DataStore     datastore.py:1520 DEBUG Starting thread 0
06/22/04 17:29:29 1872 DataStore     datastore.py:1528 DEBUG Worker 0
starting
06/22/04 17:29:29 484 DataStore     datastore.py:1522 DEBUG Waiting thread 0
06/22/04 17:29:29 484 DataStore     datastore.py:1515 DEBUG Creating thread 1
06/22/04 17:29:29 484 DataStore     datastore.py:1520 DEBUG Starting thread 1
06/22/04 17:29:29 1840 DataStore     datastore.py:1528 DEBUG Worker 1
starting
06/22/04 17:29:29 484 DataStore     datastore.py:1522 DEBUG Waiting thread 1
06/22/04 17:29:29 484 DataStore     datastore.py:1515 DEBUG Creating thread 2
06/22/04 17:29:29 484 DataStore     datastore.py:1520 DEBUG Starting thread 2
06/22/04 17:29:29 1440 DataStore     datastore.py:1528 DEBUG Worker 2
starting
06/22/04 17:29:29 484 DataStore     datastore.py:1522 DEBUG Waiting thread 2
06/22/04 17:29:29 484 DataStore     datastore.py:1515 DEBUG Creating thread 3
06/22/04 17:29:29 484 DataStore     datastore.py:1520 DEBUG Starting thread 3
06/22/04 17:29:29 1772 DataStore     datastore.py:1528 DEBUG Worker 3
starting
06/22/04 17:29:29 484 DataStore     datastore.py:1522 DEBUG Waiting thread 3
06/22/04 17:29:29 484 DataStore     datastore.py:1525 DEBUG Done creating
workers
06/22/04 17:29:29 484 EventService     eventserviceasynch.py:409 DEBUG
EventServiceAsynch: Event Service Started
06/22/04 17:29:29 484 EventService     eventserviceasynch.py:449 DEBUG
EventServiceAsynch: Bound to 8002
(server_address=('b48133.dhcp.futures.bt.co.uk', 8002))
06/22/04 17:29:29 484 EventService     eventserviceasynch.py:468 DEBUG
EventServiceAsynch: Event service start
06/22/04 17:29:29 484 TextService     textserviceasynch.py:415 DEBUG
TextServiceAsynch: Text Service Started
06/22/04 17:29:29 484 TextService     textserviceasynch.py:449 DEBUG
TextServiceAsynch: Bound to 8004
(server_address=('b48133.dhcp.futures.bt.co.uk', 8004))
06/22/04 17:29:29 484 TextService     textserviceasynch.py:468 DEBUG
TextServiceAsynch: Text service start
06/22/04 17:29:29 484 TextService     textserviceasynch.py:474 DEBUG
TextServiceAsynch: register_listen returns '_a89ab900_p_callbackStruct'
06/22/04 17:29:29 484 VenueServer     venueserver.py:338 DEBUG Reading
persisted Venues from: VenueServer.dat
06/22/04 17:29:29 484 VenueServer     venueserver.py:343 DEBUG Loading
06/22/04 17:29:29 484 VenueServer     venue.py:341 DEBUG ------------
STARTING VENUE
06/22/04 17:29:29 484 VenueServer     venue.py:382 INFO  Venue URI
06/22/04 17:29:29 484 EventService     eventserviceasynch.py:769 DEBUG
EventServiceAsynch: AddChannel 000000fd4cba42a60084009200700085409
06/22/04 17:29:29 484 TextService     textserviceasynch.py:754 DEBUG
TextServiceAsynch: AddChannel 000000fd4cba42a60084009200700085409
06/22/04 17:29:29 484 VenueServer     venue.py:387 DEBUG Registering
heartbeat for 000000fd4cba42a60084009200700085409
06/22/04 17:29:29 484 VenueServer     venue.py:404 DEBUG data store
06/22/04 17:29:29 484 DataStore     datastore.py:273 DEBUG Reading
Data\000000fd4cba42a60084009200700085409\DataStore.dat
06/22/04 17:29:29 484 VenueServer     venue.py:428 INFO  Have upload url:
https://b48133.dhcp.futures.bt.co.uk:8006/000000fd4cba42a60084009200700085409
06/22/04 17:29:29 484 VenueServer     venue.py:996 DEBUG Calling
SetConnections.
06/22/04 17:29:29 484 VenueServer     venue.py:1784 DEBUG
CreateApplication: name=Basic Image - 05:26:53 PM June 22, 2004
description=Started by Benedikt Bjarni Bogason, BBB at 05:26:53 PM June
22, 2004
EventServiceAsynch: AddChannel 000000fd4d30cce50084009200700085a70
06/22/04 17:29:29 484 EventService     eventserviceasynch.py:761 DEBUG
EventServiceAsynch: GetLocation
06/22/04 17:29:29 484 SharedApplication     sharedapplication.py:422 DEBUG
Returning channel_id='000000fd4d30cce50084009200700085a70'
loc='('b48133.dhcp.futures.bt.co.uk', 8002)'
06/22/04 17:29:29 484 VenueServer     venue.py:1821 DEBUG
CreateApplication: Created id=000000fd4d2e708e00840092007000855cb
handle=https://b48133.dhcp.futures.bt.co.uk:8000/Venues/000000fd4cba42a60084009200700085409/apps/000000fd4d2e708e00840092007000855cb
06/22/04 17:29:29 484 VenueServer     venueserver.py:483 WARNING No option
'authorizationpolicy' in section: '000000fd4cba42a60084009200700085409'
06/22/04 17:29:29 484 VenueServer     venueserver.py:269 DEBUG CFG:
Default Venue: 000000fd4cba42a60084009200700085409
06/22/04 17:29:29 484 VenueServer     venueserver.py:271 DEBUG Setting
default venue.
06/22/04 17:29:29 484 VenueServer     venueserver.py:849 INFO  Setting
default venue; oid=000000fd4cba42a60084009200700085409
06/22/04 17:29:29 1224 VenueServer     venueserver.py:647 INFO
Checkpointing completed at Tue Jun 22 17:29:29 2004.
06/22/04 17:29:30 484 Toolkit     venueserver.py:96 DEBUG Starting Hosting
Environment.
06/22/04 17:30:29 1224 VenueServer     venueserver.py:647 INFO
Checkpointing completed at Tue Jun 22 17:30:29 2004.
06/22/04 17:31:07 1400 VenueServer     venue.py:2103 INFO  Authorizing
action: Enter for subject /O=Access
06/22/04 17:31:07 1400 VenueServer     venue.py:2135 DEBUG Interface
Enter: Called.
06/22/04 17:31:07 1400 VenueServer     venue.py:1081 DEBUG Enter called.
06/22/04 17:31:07 1400 VenueServer     venue.py:1088 DEBUG Enter:
Assigning private id: 000000fd4d324ca800840092007000851bb
06/22/04 17:31:07 1400 VenueServer     venue.py:811 DEBUG added user as
producer of non-existent stream
06/22/04 17:31:07 1400 VenueServer     venue.py:3292 DEBUG * * * Added
stream producer 000000fd4d324ca800840092007000851bb
06/22/04 17:31:07 1400 VenueServer     venue.py:1107 DEBUG Current users:
06/22/04 17:31:07 1400 VenueServer     venue.py:1109 DEBUG
VenueClientState(name=Benedikt Bjarni Bogason, BBB
privateID=000000fd4d324ca800840092007000851bb lastHeartbeat=1087921867.95)
06/22/04 17:31:07 1400 VenueServer     venue.py:1110 DEBUG Enter:
Distribute enter event
06/22/04 17:31:07 1400 EventService     eventserviceasynch.py:761 DEBUG
06/22/04 17:31:07 1400 TextService     textserviceasynch.py:729 DEBUG
TextServiceAsynch: GetLocation
06/22/04 17:31:08 1400 VenueServer     venue.py:1121 DEBUG state:
<AccessGrid.Descriptions.VenueState instance at 0x027B0F58>
06/22/04 17:31:08 1400 VenueServer     venue.py:2103 INFO  Authorizing
action: GetStreams for subject /O=Access
06/22/04 17:31:09 1416 EventService     eventserviceasynch.py:299 DEBUG
EventServiceAsynch: Attempting authorization on event Connect
06/22/04 17:31:09 1416 VenueServer     venue.py:1033 DEBUG Venue gets
channelAuthCallback, privateID=000000fd4d324ca800840092007000851bb
06/22/04 17:31:09 1416 VenueServer     venue.py:1037 DEBUG Private id is
in client list, authorizing
06/22/04 17:31:09 1416 VenueServer     venue.py:260 DEBUG Set connection
for Benedikt Bjarni Bogason, BBB
06/22/04 17:31:09 1416 EventService     eventserviceasynch.py:317 DEBUG
EventServiceAsynch: Auth callback <bound method Venue.channelAuthCallback
of Venue: name=Venue Server Lobby id=18043928
url=https://b48133.dhcp.futures.bt.co.uk:8000/Venues/000000fd4cba42a60084009200700085409>
returns 1
06/22/04 17:31:09 1416 EventService     eventserviceasynch.py:700 DEBUG
EventServiceAsynch: Adding connObj 000000fd4d3251270084009200700085e33 to
channel 000000fd4cba42a60084009200700085409
06/22/04 17:31:09 1416 EventService     eventserviceasynch.py:342 DEBUG
EventServiceAsynch: Specific event callback=<bound method
Venue.ClientHeartbeat of Venue: name=Venue Server Lobby id=18043928
06/22/04 17:31:09 1932 VenueServer     venue.py:2103 INFO  Authorizing
action: GetUploadDescriptor for subject /O=Access
06/22/04 17:31:09 1936 TextService     textserviceasynch.py:474 DEBUG
06/22/04 17:31:10 1944 TextService     textserviceasynch.py:302 DEBUG
TextServiceAsynch: Attempting authorization on event Connect
06/22/04 17:31:10 1944 TextService     textserviceasynch.py:326 DEBUG
TextServiceAsynch: Default authorization (no callback registered)
06/22/04 17:31:10 1944 TextService     textserviceasynch.py:682 DEBUG
TextServiceAsynch: Adding connObj 000000fd4d32540c008400920070008513d to
06/22/04 17:31:14 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:19 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:24 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:29 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:30 1224 VenueServer     venueserver.py:647 INFO
Checkpointing completed at Tue Jun 22 17:31:30 2004.
06/22/04 17:31:34 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:39 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:44 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:49 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:54 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:31:59 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:04 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:09 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:14 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:19 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:20 1416 EventService     eventserviceasynch.py:342 DEBUG
Venue.EventServiceClientExits of Venue: name=Venue Server Lobby
id=18043928
06/22/04 17:32:20 1416 VenueServer     venue.py:750 DEBUG VenueServer: Got
Client exiting for 000000fd4d324ca800840092007000851bb
06/22/04 17:32:21 1424 VenueServer     venue.py:2103 INFO  Authorizing
action: Exit for subject /O=Access
06/22/04 17:32:21 1424 VenueServer     venue.py:1553 DEBUG Called Venue
Exit on 000000fd4d324ca800840092007000851bb
06/22/04 17:32:21 1424 VenueServer     venue.py:916 DEBUG Called
RemoveUser on 000000fd4d324ca800840092007000851bb
06/22/04 17:32:21 1424 VenueServer     venue.py:3396 DEBUG
StreamDescriptionList.index Address 224.2.239.117 224.2.239.117
06/22/04 17:32:21 1424 VenueServer     venue.py:3399 DEBUG
StreamDescriptionList.index Port 54588 54588
06/22/04 17:32:21 1424 VenueServer     venue.py:948 DEBUG Removing single
instance of user
06/22/04 17:32:21 1424 EventService     eventserviceasynch.py:511 DEBUG
EventServiceAsynch: Removing connection
06/22/04 17:32:21 1936 EventService     eventserviceasynch.py:152 DEBUG
EventServiceAsynch: readCallback returned failure: -1 8
06/22/04 17:32:21 1936 EventService     eventserviceasynch.py:196 INFO
EventServiceAsynch: IOBase exception on event service close (probably ok)
06/22/04 17:32:21 1416 EventService     eventserviceasynch.py:582 DEBUG
EventServiceAsynch: EOF on connection 000000fd4d3251270084009200700085e33
06/22/04 17:32:21 1424 EventService     eventserviceasynch.py:516 DEBUG
000000fd4d3251270084009200700085e33 from channel
06/22/04 17:32:21 1416 EventService     eventserviceasynch.py:511 DEBUG
06/22/04 17:32:21 1424 VenueServer     venue.py:965 DEBUG RemoveUser:
Distribute EXIT event
06/22/04 17:32:21 1424 VenueServer     venue.py:245 DEBUG Enqueue event of
type Exit for Benedikt Bjarni Bogason, BBB
06/22/04 17:32:21 1416 EventService     eventserviceasynch.py:196 INFO
06/22/04 17:32:21 1416 EventService     eventserviceasynch.py:516 DEBUG
06/22/04 17:32:21 1416 EventService     eventserviceasynch.py:393 ERROR
RemoveConnection: connection 000000fd4d3251270084009200700085e33 not in
connection list
06/22/04 17:32:24 1944 TextService     textserviceasynch.py:337 DEBUG
TextServiceAsynch: EventConnection: Removing client
connection to 000000fd4cba42a60084009200700085409
06/22/04 17:32:24 1944 TextService     textserviceasynch.py:512 DEBUG
TextServiceAsynch: Removing connection 000000fd4d32540c008400920070008513d
06/22/04 17:32:24 1936 TextService     textserviceasynch.py:161 DEBUG
TextServiceAsynch: readCallback returned failure: -1 17
06/22/04 17:32:24 1936 TextService     textserviceasynch.py:203 INFO
TextServiceAsynch: IOBase exception on text service close (probably ok)
06/22/04 17:32:24 1944 TextService     textserviceasynch.py:582 DEBUG
TextServiceAsynch: EOF on connection 000000fd4d32540c008400920070008513d
06/22/04 17:32:24 1944 TextService     textserviceasynch.py:203 INFO
06/22/04 17:32:27 1528 VenueServer     venue.py:2103 INFO  Authorizing
06/22/04 17:32:27 1528 VenueServer     venue.py:2135 DEBUG Interface
Enter: Called.
06/22/04 17:32:27 1528 VenueServer     venue.py:1081 DEBUG Enter called.
06/22/04 17:32:27 1528 VenueServer     venue.py:1088 DEBUG Enter:
Assigning private id: 000000fd4d33821f0084009200700085ff3
06/22/04 17:32:27 1528 VenueServer     venue.py:811 DEBUG added user as
06/22/04 17:32:27 1528 VenueServer     venue.py:3292 DEBUG * * * Added
stream producer 000000fd4d33821f0084009200700085ff3
06/22/04 17:32:27 1528 VenueServer     venue.py:1107 DEBUG Current users:
06/22/04 17:32:27 1528 VenueServer     venue.py:1109 DEBUG
privateID=000000fd4d33821f0084009200700085ff3 lastHeartbeat=1087921947.18)
06/22/04 17:32:27 1528 VenueServer     venue.py:1110 DEBUG Enter:
06/22/04 17:32:27 1528 EventService     eventserviceasynch.py:761 DEBUG
06/22/04 17:32:27 1528 TextService     textserviceasynch.py:729 DEBUG
06/22/04 17:32:27 1528 VenueServer     venue.py:1121 DEBUG state:
<AccessGrid.Descriptions.VenueState instance at 0x011A00F8>
06/22/04 17:32:29 1224 VenueServer     venueserver.py:647 INFO
Checkpointing completed at Tue Jun 22 17:32:29 2004.
06/22/04 17:32:30 992 VenueServer     venue.py:2103 INFO  Authorizing
06/22/04 17:32:31 1416 EventService     eventserviceasynch.py:75 DEBUG
EventServiceAsynch: ConnectionHandler delete
06/22/04 17:32:31 1416 EventService     eventserviceasynch.py:299 DEBUG
06/22/04 17:32:31 1416 VenueServer     venue.py:1033 DEBUG Venue gets
channelAuthCallback, privateID=000000fd4d33821f0084009200700085ff3
06/22/04 17:32:31 1416 VenueServer     venue.py:1037 DEBUG Private id is
06/22/04 17:32:31 1416 VenueServer     venue.py:260 DEBUG Set connection
06/22/04 17:32:31 1416 EventService     eventserviceasynch.py:317 DEBUG
returns 1
06/22/04 17:32:31 1416 EventService     eventserviceasynch.py:700 DEBUG
EventServiceAsynch: Adding connObj 000000fd4d3390d500840092007000850ac to
06/22/04 17:32:31 1416 EventService     eventserviceasynch.py:342 DEBUG
06/22/04 17:32:32 1400 VenueServer     venue.py:2103 INFO  Authorizing
06/22/04 17:32:33 1936 TextService     textserviceasynch.py:474 DEBUG
06/22/04 17:32:33 1944 TextService     textserviceasynch.py:80 DEBUG
TextServiceAsynch: ConnectionHandler delete
06/22/04 17:32:33 1944 TextService     textserviceasynch.py:302 DEBUG
06/22/04 17:32:33 1944 TextService     textserviceasynch.py:326 DEBUG
06/22/04 17:32:33 1944 TextService     textserviceasynch.py:682 DEBUG
TextServiceAsynch: Adding connObj 000000fd4d3398d00084009200700085b18 to
06/22/04 17:32:34 1936 EventService     eventserviceasynch.py:152 DEBUG
EventServiceAsynch: readCallback returned failure: -1 33
06/22/04 17:32:34 1416 EventService     eventserviceasynch.py:582 DEBUG
EventServiceAsynch: EOF on connection 000000fd4d3390d500840092007000850ac
06/22/04 17:32:34 1416 EventService     eventserviceasynch.py:511 DEBUG
06/22/04 17:32:34 1944 TextService     textserviceasynch.py:337 DEBUG
06/22/04 17:32:34 1944 TextService     textserviceasynch.py:512 DEBUG
TextServiceAsynch: Removing connection 000000fd4d3398d00084009200700085b18
06/22/04 17:32:34 1416 EventService     eventserviceasynch.py:196 INFO
06/22/04 17:32:34 1416 EventService     eventserviceasynch.py:516 DEBUG
000000fd4d3390d500840092007000850ac from channel
06/22/04 17:32:34 1528 TextService     textserviceasynch.py:161 DEBUG
TextServiceAsynch: readCallback returned failure: -1 37
06/22/04 17:32:34 1528 TextService     textserviceasynch.py:203 INFO
06/22/04 17:32:34 1944 TextService     textserviceasynch.py:582 DEBUG
TextServiceAsynch: EOF on connection 000000fd4d3398d00084009200700085b18
06/22/04 17:32:34 1944 TextService     textserviceasynch.py:203 INFO
