[AG-TECH] internal venue server
    MPremkumar at lbl.gov
    Mon Jun 21 12:31:22 CDT 2004
> The only issue that I can think of re: RedHat 9 is that you
> probably will
> have to acquire and load the openssl096 and openssl096b packages
> from your
> favourite RedHat mirror.  Oh, yes - with 2.2 you will run into an
> issuewith python-optik (bugzilla'd already) - but the way that I
> dealt with
> that is just to remove up2date (you'll have to get rid of a couple of
> other packages as well), since the RedHat Network no longer applies
> forthis release.  Once you've removed up2date and the RedHat
> version of
> python-optik, the install of 2.2 is clean.
Actually i have the same problem, but when i tried to remove the up2date package, it failed because of dependencies.
 up2date is needed by (installed) firstboot-1.0.5-11
 up2date = 3.1.23.2 is needed by (installed) up2date-gnome-3.1.23.2-1
 /usr/share/rhn/RHNS-CA-CERT is needed by (installed) rhn-applet-2.0.9-0.9.0.1
Randy, is that ok to remove these packages ?
Thanks
Madhan
Student Assistant
LBNL, Berkeley
> You will definitely need certificates - there is no way around
> that.  I
> haven't attempted to configure our setup to only use our internal CA
> (though I believe that it is possible) - that's one of the items on
> my to
> do list.
> -randy
> On Mon, 21 Jun 2004, Benedikt Bjarni Bogason wrote:
> > Hello everybody.
> > I am in the process of looking into setting up an internal venue
> server> for my company (BT) behind our firewalls. I understand this
> has been done,
> > at least with one company (Boeing). For the time being we are only
> > thinking about connecting maybe 4-5 clients, mostly PIGs, but if
> > successful we might extend it further. Right now we are looking
> into the
> > possibility of one or two of our colleagues working from home
> using a
> > broadband connection (firewall problem not an issue).
> > For this trial run we will be using as a server an old Linux box,
> and were
> > wondering if any of you had any suggestions which flavour of
> Linux we
> > should be using. Is there a particular version that works better
> for AG2.2
> > than others?
> > And also, will there be any severe certificate problems? As it
> will be
> > only used within the company, within our firewalls, we really
> have no
> > practical use for them; I don't suppose there is any way of just
> skipping> them? If not, would it be difficult to run our own
> certificate server?
> > If anyone has any useful tips, or has gone through this process
> before us
> > and is willing to warn us of the pitfalls, I would be very grateful.
> > Best regards,
> > Benedikt Bogason
> > benedikt.bogasson at bt.com
