[AG-TECH] Fedora 2
    Sugree Phatanapherom
    sugree at hpcnc.cpe.ku.ac.th
    Wed Jun 16 10:09:51 CDT 2004
Hi all,
> Hi Michael,
> > Has anyone made progress on installing AGtk 2.2 on Fedora 2?
> I've been working on building the AGtk 2.2 on Fedora Core 2.
I have just successfully building AG 2.2 on Fedora Core 2.
> > I'm getting this:
> > Installing package: AccessGrid
> > error: Failed dependencies:
> >          wxPythonGTK-py2.2 is needed by AccessGrid-2.2-6
> I've asked that the 'Requires' dependency on 'wxPythonGTK-py2.2' be
changed
> to 'wxPython' in the AccessGrid.spec.in file in CVS. With this change, the
> wxPythonGTK-py2.2 package available on the RH7.3 AGtk 2.2 download page
and
> wxPythonGTK2 from Fedora Extras will both satisfy the 'wxPython'
dependency.
Umm. It seems I did wrong to change wxPythonGTK-py2.2 to wxPythonGTK-py2.3.
> Unfortunately wxPythonGTK2 available from Fedora Extras (www.fedora.us)
> doesn't work with GNOME 2.6, due to a bug with wxGTK2,  see:
>     https://bugzilla.fedora.us/show_bug.cgi?id=1641
> Fortunately, as the wxGTK 2.4.2 bug report states, in the interim there is
a
> version of wxGTK2 that works with Fedora Core 2 available at:
>   http://resare.com/noa/rpms/fedora-2/
I instead use wxGTK 2.4.0 from http://www.wxpython.org/ and
wxPythonGTK-py2.3 2.4.2.4 from http://www.wxwindows.org/
> >          xawtv is needed by AccessGrid-2.2-6
> xawtv no longer comes with Fedora Core 2, but you can install the version
> from Fedora Core 1.
I get xawtv 3.92 from dag repository at
http://dag.wieers.com/packages/xawtv/xawtv-3.92-1.1.fc2.dag.i386.rpm.
> >          libcrypto.so.2 is needed by AccessGrid-2.2-6
> >          libssl.so.2 is needed by AccessGrid-2.2-6
> I don't get that problem when built from source.
Me too.
> > Should I try the source? or do I need to install additional components?
> You might want to wait till AccessGrid.spec.in is updated in CVS before
> building from source. I think I could make an AGtk 2.2 RPM for Fedora Core
2
> available in the interim (I need to get it from my home PC), till
> AccessGrid.spec.in gets updated in CVS.
I also have to modify gpt 3.0.1 due to misuse of $withval in configure. Umm.
It might be old source. Anyway, it works properly right now.
If you want to try my build, you can download it via below link.
http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/packages/AccessGrid-2.2-6.fc2.tar.gz
If you just want RPMS, check out below link.
http://osl.cpe.ku.ac.th/pub/accessgrid/fedora/linux/core/2/RPMS/
Otherwise, you can also install it using yum.
[accessgrid]
name=Access Grid
baseurl=http://osl.cpe.ku.ac.th/pub/fedora/linux/core/$releasever
Then simply run:
yum groupinstall agtk
Good luck,
