[AG-TECH] AG2.2 networking configuration
    Brian Corrie
    bcorrie at sfu.ca
    Fri Jun 18 17:28:54 CDT 2004
Hi Ivan,
Speaking of replacements for programs in AG 2.2 I noticed a problem
recently. In 2.1.2 when my PIG node changed locations (home to office
etc) there was an app that started up that changed the GLOBUS_HOSTNAME
variable. I am not sure what it was called but it detected a change in
the networking config and asked if I wanted to change the variable... On
2.2 this does not seem to happen - is that correct? I had to go into the
environment variables and change it explicitly to get it to work from
home...
Do you still have that app or some sort of replacement for it?
Cheers,
Brian
Ivan R. Judson wrote:
> That makes sense, clearly the discovery of devices in that code is platform
> specific.
> If you can write a python function that enumerates them we can integrate
> that as a patch.
> --Ivan
>>-----Original Message-----
>>From: dgolden at cp.dias.ie [mailto:dgolden at cp.dias.ie]
>>Sent: Friday, June 18, 2004 9:43 AM
>>To: judson at mcs.anl.gov
>>Cc: ag-tech at mcs.anl.gov
>>Subject: RE: [AG-TECH] AG2.2 replacement for setupvideo.py
>>>We'll have to sort out what's going on.
>>Haven't filed a formal bug report yet, but I immediately saw
>>the problem once pointed to that method:
>>/proc/video/dev doesn't exist at all on my system...
>>(stock debian 2.6 kernel).
>>In kernel 2.6 , the information is available via sysfs in
>>/sys/class/video4linux not /proc/video/dev ...
>>In 2.6 there has been a move to rationalise the /proc fs to
>>be for processes only, and the sundry kernel stuff to /sys
>>Neater that way, I guess.
>>Best Regards,
>>David Golden
