[AG-TECH] AG 2.2 Shared Apps
Brian Corrie
bcorrie at sfu.ca
Thu Jun 17 23:30:40 CDT 2004
Hello all (mostly Argonne folks),
I "think" I have written an AG 2.2 shared application. My question is
about backwards compatibility with AG 2.1.2 venue servers etc.
I can successfully register my shared app with agpm on my 2.2 client on
my laptop. When I connect to a 2.1.2 venue server sure enough it shows
up in the client as a shard app. I can even add it as a shared app to a
venue. That is where I hit a snag. Should I be able to run a 2.2 shared
app, using a 2.2 Venue Client, but with a 2.1.2 venue server???
It appears not thus far... The first clue is that the app URL that is in
the Properties dialog for the shared app has the form
https://venueserver.netera.ca:8000/112. This is the 2.1.2 form I
believe. In looking at Susanne's Shared Question Tool her test stub has
a URL of the form
https://venueserver.netera.ca:8000/Venues/default/apps/somebighexstring.
When I try to open the shared app in the venue client I get nothing...
no errors, no results! When I run my shared app from the command line
(this used to work in 2.1.2) I get a credential error as enclosed below.
I suspect this is the same problem (although the shared app doesn't tell
me anything when I run it from within the Venue Client). I am using the
app URL from the properties dialog in the client.
Any thoughts?
Cheers,
Brian
p.s. Where does the log file go when you run something from within the
venue client??? I could not find it in the Logs directory...
06/17/04 21:07:45 724 SharedVizServer venuevizserverclient.py:263
DEBUG SharedVizServer.__init__:Started shared vizserver appUrl
https://venues.cns.ualberta.ca:8000/110, debug 1, log SharedVizServer.log
06/17/04 21:07:45 724 Toolkit toolkit.py:79 DEBUG Initializing AG
Toolkit version 2.2
06/17/04 21:07:45 724 SharedVizServer sharedappclient.py:110 ERROR
SharedAppClient.Join failed: https://venues.cns.ualberta.ca:8000/110
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\SharedAppClient.py",
line 105, in Join
(self.__publicId, self.__privateId) =
self.__appProxy.Join(clientProfile)
File "C:\Python23\Lib\site-packages\AccessGrid\SharedApplication.py",
line 553, in Join
return self.proxy.Join(clientProfile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
__call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
__r_call
self.__hd, self.__ma)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in
__call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in
connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: no credentials:
Problem with local credentialsunable to access trusted certificates in:
x509_cert_dir=C:\Documents and Settings\All Users\Application
Data\AccessGrid\certificates
Function:proxy_init_cred
06/17/04 21:07:45 724 SharedVizServer sharedappclient.py:118 ERROR
line 113, in Join
(self.__publicId, self.__privateId) = oldAppProxy.Join()
__call__
__r_call
__call
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
connect
raise ex
Brian
